resleeving an h22a
Old May 27, 2003 | 06:06 PM
ID_ten_T's Avatar
Default resleeving an h22a
why is it necessary to resleeve an h22a when upgrading to forged internals?
Old May 27, 2003 | 06:15 PM
Ima2nr's Avatar
Default Re: resleeving an h22a (ID_ten_T)
because Honda used a fiber reinforced sleeve that is not compatable with forged pistons. you will experience serious damage to the walls of the stock sleeves that will cause you engine to loose compression and start to use oil.
Old May 27, 2003 | 09:13 PM
Mikeyslude's Avatar
You will have to resleeve.
Here is a pic of my block done by GE.
Old May 27, 2003 | 09:24 PM
Lousy Beans's Avatar
Default Re: resleeving an h22a (Mikeyslude)
Even though it is the crappiest magazine ever, ImportRacer did an article on sleeving an H22 last month (2F2F on the cover). It had some good pics and went into pretty good detail.
Old May 27, 2003 | 10:18 PM
PrecisionH23a's Avatar
Default Re: resleeving an h22a (Ima2nr)
because the search engine says so
Old May 27, 2003 | 10:35 PM
b_ricker's Avatar
Default Re: resleeving an h22a (GudeH23a)
I too just sent it out to have it resleeved by GE........... for block sleeve, pistons and bore & hone it was $1391 on my H23a......
turbo_d
Nov 17, 2009 06:10 PM
hondabigblock
Dec 7, 2008 05:41 AM
mr_carman007
Aug 27, 2006 12:44 PM
CloudDragon
Apr 17, 2003 03:22 PM
mike4
May 7, 2002 09:44 AM
