!!!H&R----KYB AGX----DC Sports???
Old May 27, 2003 | 05:09 PM
almightyaccord's Avatar
Default !!!H&R----KYB AGX----DC Sports???
OK i have a 92 Accord SE 4dr and i am going to re-do my suspension because the stock is getting boring and i want to be slammed to the ground. So my question is what do you guys think this setup.
I'm getting KYB AGX shock/struts and H&R race springs which give me a 2.2 drop in the front and a 2.0 drop in the rear. Along with these suspension up grades i will be getting a DC sports front strut tower bar and DC sports rear lower tie down bar. Well thats about it i think i want to add something else and i know i am missing something else, if you guys have any suggestions i would greatly appricate it.
Also a quick side question would i need a Camber kit since i am going so slow or am i ok. Also if i need it a camber kit does it matter which one i buy b/c i heard they are all the same or should i buy the Ingalls kit?? Well thats its.
Old May 27, 2003 | 07:27 PM
azian21485's Avatar
Default Re: !!!H&R----KYB AGX----DC Sports??? (almightyaccord)
your going to need a camber kit..also a drop past 1.5 or 1.75 (i forgot which one) will void the warranty for the kyb agx...with that much of a drop you might want to look at higher performance shocks like koni yellows or reds, tokico illuminas or others...but if ur juss going for looks the kyb agx should do fine but im not sure how long they'll last before/if they blow
Modified by azian21485 at 5:56 AM 5/28/2003
Old May 27, 2003 | 09:27 PM
iam7head's Avatar
Default Re: !!!H&R----KYB AGX----DC Sports??? (azian21485)
Get some sway bar also, they are the king.
Race is kool if you like it slammed you going to have negative camber tho'
try koni yellow shock
eymnewdc4
Jul 29, 2005 10:45 PM
dawrenn
Suspension & Brakes
31
Jan 26, 2005 09:52 AM
almightyaccord
May 27, 2003 08:44 PM
neo1z
Sep 17, 2001 06:34 PM
Yyz
Jul 13, 2001 07:51 PM
