all motor cams???
Old May 27, 2003 | 03:59 PM
isp built's Avatar
Default all motor cams???
what would the best all motor big cam to go with be??
skunk 2 stage3?
jun 3?
toda c's or d's
what else is on the market that will make good power last and work with a 2.0 b-series 13:1 setup????
thanks
Old May 27, 2003 | 04:04 PM
J2turbo21's Avatar
Default Re: all motor cams??? (isp built)
Jerry built is make 262whp with jun3's.
EDIT:Whats your setup and is it just drag racing or daily driven.
Old May 27, 2003 | 04:29 PM
isp built's Avatar
Default Re: all motor cams??? (J2turbo21)
b20b sleved
arias 13:1
eagle rods
street car dailey driven
Old May 27, 2003 | 04:46 PM
J2turbo21's Avatar
Is it gonna have a vtec head?
Old May 27, 2003 | 04:52 PM
jasonp's Avatar
web cams make a custom grind cam for about $635.00 they make for your specific motor application
Old May 27, 2003 | 05:08 PM
RS Machines's Avatar
We have a new street/race v-tec cam that we have released that makes 5 hp across the graph compared to your big name companies on the market. They are billet cams not regrinds. For inquires please call the shop 310-328-5514 or check out the web site http://www.rsmachines.com
Old May 27, 2003 | 05:16 PM
thegrinch's Avatar
Default Re: all motor cams??? (RS Machines)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RS Machines &raquo;</TD></TR><TR><TD CLASS="quote">We have a new street/race v-tec cam that we have released that makes 5 hp across the graph compared to your big name companies on the market. They are billet cams not regrinds. For inquires please call the shop 310-328-5514 or check out the web site http://www.rsmachines.com </TD></TR></TABLE>
What are the specs? (lift, duration, etc.)
Old May 27, 2003 | 05:29 PM
J2turbo21's Avatar
Can you tell us more about these cams.
Old May 27, 2003 | 05:49 PM
CD8's Avatar
CD8
and is there applications for the h22a ?
Old May 27, 2003 | 06:07 PM
TheTruth709's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by isp built &raquo;</TD></TR><TR><TD CLASS="quote">b20b sleved
arias 13:1
eagle rods
street car dailey driven</TD></TR></TABLE>
sorry to get off subject but what kind of sleeves did u use on ur b20? and around how much they go for ? i got a b20 i want to resleve but im not sure wich sleves are the best
Old May 27, 2003 | 06:29 PM
MidoriEK4's Avatar
Default Re: all motor cams??? (TheTruth709)
how much for a set?
Old May 27, 2003 | 06:31 PM
Suprdave's Avatar
Are those EF-1 Cams?
Suprdave
Old May 27, 2003 | 07:46 PM
Tbone's Avatar
Default Re: all motor cams??? (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">Are those EF-1 Cams?
Suprdave</TD></TR></TABLE>
Nope those are rs cams.
J2turbo21's Avatar
Those are rs machine cams.I got the pic from their website.
Old May 27, 2003 | 07:52 PM
MidoriEK4's Avatar
no one has the price or the specs on them?
Old May 28, 2003 | 11:25 AM
C_A_T's Avatar
Toda D's make tremendous power, but I wouldn't use them on a street car. 2.0 liters and 13:1 compression is treading on the minimums to really get these cams working. Plus, you better know your VtoP clearances before installing them.
C_A_T
Old May 28, 2003 | 12:39 PM
b19coupe's Avatar
You will also need to upgrade your fuel system/management to run that motor. Bigger injectors and a standalone, or a good piggyback system. Clay the motor to double check you valve-to-piston clearances too.
Old May 28, 2003 | 01:22 PM
isp built's Avatar
Default Re: all motor cams??? (NA CRX Si)
la sleves
about $250.00 + install
Old May 28, 2003 | 01:26 PM
isp built's Avatar
Default Re: all motor cams??? (jasonp)
yes a vtec head b16a
Old May 28, 2003 | 01:34 PM
dohcsideSi's Avatar
i have a b20 13:1 and skunk stage 3's (should do 240+whp)....i have a brand new set of stage 3's in the box...$700 shipped.
Old May 28, 2003 | 01:58 PM
Default Re: all motor cams??? (dohcsideSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcsideSi &raquo;</TD></TR><TR><TD CLASS="quote">i have a b20 13:1 and skunk stage 3's (should do 240+whp)....i have a brand new set of stage 3's in the box...$700 shipped. </TD></TR></TABLE>
hey hit me up on the im or email me, thetruth709@aol.com im interested on your camz, let me know
Old May 28, 2003 | 04:22 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: all motor cams??? (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">You will also need to upgrade your fuel system/management to run that motor. Bigger injectors and a standalone, or a good piggyback system.</TD></TR></TABLE>
Hopefully you already knew this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Clay the motor to double check you valve-to-piston clearances too.</TD></TR></TABLE>
I would do this for anything over a stage 2/b for your set-up running 13:1's.
What kinda goals are you looking for?
Old May 29, 2003 | 08:07 AM
AllMotorMadness's Avatar
Got a set in hand dyno testing soon........
Old May 29, 2003 | 10:31 AM
QCKGSR's Avatar
Default Re: all motor cams??? (AllMotorMadness)
those are some sick *** cam's
Old May 29, 2003 | 02:54 PM
Cams will run you around $750 for just cams
$1150 for cams, titanium Retainers, and dual Valvesprings
