rear 4dr EG/EK door handles for keyless entry?
Old May 27, 2003 | 01:42 PM
wickedEFguy's Avatar
Default rear 4dr EG/EK door handles for keyless entry?
I thinking of just trying to fit some rear 4dr handles from a EG/Ek instead of just shaving the handles on my EF and disconnect the inside locks so that it will be nearly impossible to open the door since there wouldn't be a key hole and the door lock would already be disconnected. I would rely on keyless entry. Do any of you know if this has been done at all or if the door handles will fit?
Old May 27, 2003 | 01:54 PM
andrew dc's Avatar
Default Re: rear 4dr EG/EK door handles for keyless entry? (Ninja_Jc7)
why chose the eg and ek.. the handles are more round.. you can find the 88-91 4-door sedan and use those..... and yes it has been done
Old May 27, 2003 | 02:13 PM
nautica_t's Avatar
Default Re: rear 4dr EG/EK door handles for keyless entry? (CRX25)
so the 88-91 4 Door handles will work??
i was going to ask that, cuz i was going to do the same thing..
Old May 27, 2003 | 05:29 PM
1CiViC1's Avatar
Default Re: rear 4dr EG/EK door handles for keyless entry? (nautica_t)
yes the 88-91 4dr rear handles will work. Exactly the same as the front only difference is the keyhole
Old May 27, 2003 | 05:34 PM
Hcivic88's Avatar
Default Re: rear 4dr EG/EK door handles for keyless entry? (1CiViC1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1CiViC1 &raquo;</TD></TR><TR><TD CLASS="quote">yes the 88-91 4dr rear handles will work. Exactly the same as the front only difference is the keyhole </TD></TR></TABLE>
i second that, just incase u were looking for a second oppinion from somebody before u did anything.
Old May 27, 2003 | 08:26 PM
philly-O's Avatar
Default Re: rear 4dr EG/EK door handles for keyless entry? (Hcivic88)
they fit just fine...here is my car with them on
goldenmustache
Apr 6, 2009 08:40 AM
Vincent.
May 17, 2006 12:06 PM
Boostage
Oct 6, 2004 05:43 AM
jessemarCc
Aug 12, 2004 10:49 PM
