Just got my car done after 9 months. Then it happens.
Old May 27, 2003 | 01:35 PM
RyanAutry's Avatar
Default Just got my car done after 9 months. Then it happens.
After the cars been parked for 9 months. I get it running last week thanks to Sonny & his basemap. I planned on driving the car to LA for the Honda-tech meet. Took it for a drive last night. Didn't drive it hard. But gave it a little gas.
I noticed I have a loud whine when the motor idles down. Only from 600-900rpm. It's coming from the lower part of the engine. But I can hear it best near the Crank Pulley.
I think it's a rod bearing.
Time to go find a b16a shortblock to throw in.
(anyone have any JDM b16 shortblocks laying around?)
I just wanted to vent a little. I guess I'll take this block out and give it the normal workover, pistons, sleeves, rods, ect.....
My Motor---><--- Me
Old May 27, 2003 | 01:36 PM
Sonny's Avatar
Default Re: Just got my car done after 9 months. Then it happens. (RyanAutry)
Argggh...that sucks, man.
You're sure it's a rod bearing?
Sonny
Old May 27, 2003 | 01:40 PM
Tofurky's Avatar
that sucks man.
but at least you have all those icons. that one is particularly funny.
Old May 27, 2003 | 01:45 PM
RyanAutry's Avatar
Default Re: Just got my car done after 9 months. Then it happens. (Sonny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sonny &raquo;</TD></TR><TR><TD CLASS="quote">
Sonny</TD></TR></TABLE>
No. I don't really know what it is. But I'm assuming.
As soon as I give it just the slightest amount of throttle it goes away.
GOLDBERG's Avatar
there is a dude selling a jdm b16 shortclock in the classifieds
Old May 27, 2003 | 01:53 PM
SJP0tato's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanAutry &raquo;</TD></TR><TR><TD CLASS="quote"> But I can hear it best near the Crank Pulley.
Before anything else, check the tension on your timing belt. I've seen too tight make this kind of sound from the resonation, and also too loose do the same (strange vibration in the loose belt at idle). Might want to give it a shot before doing anything too drastic.
Hope it turns out something simple,
Ryan P.
Old May 27, 2003 | 01:58 PM
RyanAutry's Avatar
Default Re: Just got my car done after 9 months. Then it happens. (SJP0tato)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SJP0tato &raquo;</TD></TR><TR><TD CLASS="quote">
Ryan P.</TD></TR></TABLE>
Absolutely.
I'll give it a shot. Thanks.
Old May 27, 2003 | 02:25 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
I hope so this is scaring me and i'm about to be boosted
Old May 27, 2003 | 02:29 PM
RyanAutry's Avatar
Default Re: Just got my car done after 9 months. Then it happens. (HybridcivicLS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">I hope so this is scaring me and i'm about to be boosted </TD></TR></TABLE>
Don't let it scare you.
Old May 27, 2003 | 02:34 PM
TeStUdO's Avatar
did you just rebuild your block, or was it your stock block from before??
Old May 27, 2003 | 02:37 PM
RyanAutry's Avatar
Default Re: (TeStUdO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">did you just rebuild your block, or was it your stock block from before??</TD></TR></TABLE>
Stock b16a2 engine.
Old May 27, 2003 | 02:38 PM
TeStUdO's Avatar
did you have any problems before?? were you even boosted before? if not it seems strange something as drastic as a rod bearing would go. maybe the noise is the oil pump
Old May 27, 2003 | 02:41 PM
93LSivic's Avatar
HOly **** man, you scared the hell out of me. I was confident this was going to be anohter car theft thread
Thank god its only a b16 short block replacement. That **** can be found for nothing cause people rape them for the head.
Old May 27, 2003 | 02:42 PM
RyanAutry's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">did you have any problems before?? were you even boosted before? if not it seems strange something as drastic as a rod bearing would go. maybe the noise is the oil pump</TD></TR></TABLE>
Yes, supercharged before.
The oil pump would make a noise like that?
Old May 27, 2003 | 02:47 PM
RyanAutry's Avatar
Default Re: (93LSivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">
Thank god its only a b16 short block replacement. That **** can be found for nothing cause people rape them for the head.</TD></TR></TABLE>
Yep, Im looking at 4 of them for under $400
Old May 27, 2003 | 03:46 PM
madman604's Avatar
um stupid question, but did you forget to put in the woodruff key in the crank pulley?
I has an aftermarket aluminum pulley ant the key fell out causing the pulley so spin/slip and amka a god awful squeeling when i accelerated or tapped the gas.
Old May 27, 2003 | 03:49 PM
RyanAutry's Avatar
Default Re: Just got my car done after 9 months. Then it happens. (Turbo E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E &raquo;</TD></TR><TR><TD CLASS="quote">um stupid question, but did you forget to put in the woodruff key in the crank pulley?
I has an aftermarket aluminum pulley ant the key fell out causing the pulley so spin/slip and amka a god awful squeeling when i accelerated or tapped the gas.</TD></TR></TABLE>
Ummm, maybe. I'll check.
Old May 27, 2003 | 03:56 PM
TeStUdO's Avatar
Default Re: (RyanAutry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanAutry &raquo;</TD></TR><TR><TD CLASS="quote">The oil pump would make a noise like that? </TD></TR></TABLE>
it might, you said it was loudest by the crank pulley. i would check the key also.
make sure the pulley is tightened down too. might sound stupid, but i would always check the small stuff first.
Old May 27, 2003 | 03:59 PM
RyanAutry's Avatar
make sure the pulley is tightened down too. might sound stupid, but i would always check the small stuff first.</TD></TR></TABLE>
I will. Thanks.
Old May 27, 2003 | 07:13 PM
BlueSi2k's Avatar
yea definately check that stuff out first it seems like your jumping to conclusions buying a new short block. At least pull the pan before dropping money on a block...my 2 cents
Old May 27, 2003 | 07:46 PM
Burke's Avatar
Banned
Default Re: (BlueSi2k)
my old b18c made some crzy whining noise at idle, i changed the t-belt and water pump and it went away. much cheaper than a new block
good luck
Old May 27, 2003 | 08:16 PM
tony1's Avatar
Umm, probably good news for you, but a rod bearing will knock, not whine...
Old May 27, 2003 | 08:32 PM
sweet's Avatar
Default Re: Just got my car done after 9 months. Then it happens. (tony1)
it's most likely something simple. definantly check it out completely before buying new parts or an entire block. dont' jump to conclusions.
if for some reason you need another block LMK cause i have a B16A block that's in excellent shape i need to get rid of, i sold the head and don't need the block any more.
Old May 27, 2003 | 09:02 PM
95c1v1cs1's Avatar
Default Re: Just got my car done after 9 months. Then it happens. (sweet)
So many times have i thought my engine was toast. It is still running like a champ to this day. Keep thinking it out, i am sure it is something small.
Old May 27, 2003 | 09:04 PM
IloveNewt's Avatar
Default Re: Just got my car done after 9 months. Then it happens. (95c1v1cs1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95c1v1cs1 &raquo;</TD></TR><TR><TD CLASS="quote">So many times have i thought my engine was toast. It is still running like a champ to this day. Keep thinking it out, i am sure it is something small. </TD></TR></TABLE>
Yea i find myself getting paranoid about every "new" sound i think my engine is making. I wish i knew what there if, if anything..........prolly me just being paranoid.
