Need help with spring install
Old May 27, 2003 | 11:50 AM
Thrillhouse's Avatar
Default Need help with spring install
I have installed springs and shocks on my teg. Tomorrow I am going to help my friend do his 96 accord. Is this a lot different? The only thing that i can think of that would be different would be the trunk area, how do i get to the strut towers in the rear? I think everything else should be similar to my car. Thx
Old May 27, 2003 | 11:52 AM
dcaccord's Avatar
Default Re: Need help with spring install (Thrillhouse)
should be pretty similar. the strut towers are under the trunk lining right where you'd think they'd be. Install should be pretty easy. Good Luck.
Old May 27, 2003 | 11:58 AM
Old Skool's Avatar
Default Re: Need help with spring install (dcaccord)
look out for the rear lca's..the bolt going through them holding the shock on likes to get rusted to the bushing...they only way you can really get it out is to press the bushing out, press a new one in, and replace the bolt..you might be able to air hammer the bolt out of the bushing but chances are it'll be in there really good
Old May 27, 2003 | 12:22 PM
Default Re: Need help with spring install (Old Skool)
How do you take out the trunk liner?
Old May 27, 2003 | 12:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thrillhouse &raquo;</TD></TR><TR><TD CLASS="quote">How do you take out the trunk liner?</TD></TR></TABLE> Sorry like i said its not my car so im not sure. My teg has those plastic covers that just pop off. Can someone tell me how to take the liner out?
Old May 27, 2003 | 02:11 PM
4DRPIMPIN's Avatar
just plastic clips that hold the liner to the trunk metal
bcbrett
Apr 13, 2005 01:12 PM
5200BB6
Suspension & Brakes
11
Mar 7, 2005 09:55 AM
5200BB6
Mar 6, 2005 09:56 AM
Flux
Nov 4, 2003 03:50 PM
TomO
Mar 24, 2002 05:25 AM
