Air Bag Light
Hello all,
I just finished putting in my new sound system over the weekend. Everything came out perfect, but when I was finished my SRS Airbag light was on. Anyone have any ideas of why this might of came on.
Thanks in advanced
Thanks in advanced
Try a quick search and see what you come up with. I had to reset the memory in my car in order to turn off the light after removing a front seat just recently, so the answer should be here.
This is what I pulled of a how-to a while ago.
1) Turn ignition switch off
2) Connect the scs service connector to the MES connector. Do not use a jumper wire
3) Turn ignition switch to on
4) The SRS indicator light will come on for about 6 seconds, and then go off. Remove the SCS service connector from the MES connector within 4 seconds after the light comes on
5) The SRS indicator will come on again. Reconnect the SCS service connector to the MES connector within 4 seconds after the light comes on.
6) When the SRS indicator light goes off, remove the SCS service connector from the MES connector within 4 seconds.
7) The SRS indicator light will blink 2 times indicating that the memory has been erased
8)Turn the ignition switch to off and wait for 10 seconds.
Someone correct me if I missed anything.
DumpedSi
Sep 11, 2003 08:42 PM
