BFG drag radials or FALKEN Azenis??
Old May 26, 2003 | 10:52 PM
preludacris's Avatar
Default BFG drag radials or FALKEN Azenis??
Modified by preludacris at 4:30 PM 4/18/2004
Old May 26, 2003 | 11:10 PM
Downey's Avatar
Default Re: BFG drag radials or FALKEN Azenis?? (preludacris)
azenis grip good.. but they are not designed to be a drag race tire. they have stiffened sidewalls so they corner good. for drag racing you want a soft sidewall so the tire will buckle and grip.
ive driven the azenis at the track and pulled 2.2 60ft's. most people pull 2.0 60ft''s with bfg's.
street use Azenis
track use bfg
Old May 26, 2003 | 11:16 PM
DIRep972's Avatar
Smarter than you
Ive driven on both. and I can honestly say i did not like the azenis at all.
possibly it was the car they were on, but they wheel hopped like crazy. they didn't hook up good either(apposed to bfg's)
somehow lots of people still manage to cut 2.0's on azenis but more people do it consistantly and easier on bfgs.
for a daily driver id consider azenis cause they last awhile and are cheap. hook up ok too.
Old May 26, 2003 | 11:40 PM
gsrvx's Avatar
New User
Default Re: BFG drag radials or FALKEN Azenis?? (DIRep)
Yea, I've cut 2.1s on Azenis...but I'd figure the BFGs would be a lot better.
Old May 27, 2003 | 01:12 AM
2001TypeR's Avatar
Well ive had both and the bfgs are way better for drag...
Old May 27, 2003 | 06:29 AM
bottlefedb18c1's Avatar
Default Re: BFG drag radials or FALKEN Azenis?? (2001TypeR)
for the money the falken i never ran the BF's but i cut a 2.2 60' and my freind cut a 2.1 60' but i do have to say the falken hooked better then my nitto 555r's on my turbo gsr
Old May 27, 2003 | 07:51 AM
turbologist's Avatar
Default Re: BFG drag radials or FALKEN Azenis?? (bottlefedb18c1)
I second that...the 555r's are junk....Get the BfGs if you plan on making some serious HP or plan on racing alot...
Old May 27, 2003 | 03:46 PM
vivid02's Avatar
Default Re: BFG drag radials or FALKEN Azenis?? (burp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burp &raquo;</TD></TR><TR><TD CLASS="quote">
agreed 555r's are junk!</TD></TR></TABLE>
3 years ago I thought I was the **** when I had 555R's on single cam on bottle.
Old May 27, 2003 | 07:16 PM
FCdrifter's Avatar
New User
Default Re: BFG drag radials or FALKEN Azenis?? (vivid02)
azeni's are sticky as hell...in the corners people!!!
super stiff sidewalls are NOT good for drag
Old May 27, 2003 | 07:23 PM
but i noticed with my old 555r's was that the side was thicker and stiffer then my falken tires
Old May 27, 2003 | 07:30 PM
fastwanabe's Avatar
Default Re: BFG drag radials or FALKEN Azenis?? (Downey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Downey &raquo;</TD></TR><TR><TD CLASS="quote">azenis grip good.. but they are not designed to be a drag race tire. they have stiffened sidewalls so they corner good. for drag racing you want a soft sidewall so the tire will buckle and grip.
ive driven the azenis at the track and pulled 2.2 60ft's . most people pull 2.0 60ft''s with bfg's.
street use Azenis
track use bfg</TD></TR></TABLE>
2.2? I do that on street tires, WTF?
Old May 27, 2003 | 07:40 PM
i have also been seeing that
Old May 28, 2003 | 10:19 AM
MAX built it's Avatar
azenis are the best bang for the buck
MHR
(562)423-6226
Old May 28, 2003 | 10:31 AM
vegan_punk's Avatar
Default Re: BFG drag radials or FALKEN Azenis?? (MAX built it)
Which ones last longer? How long do each of these last? Which bfg's are you talking about. Aren't there two different ones.
Old May 28, 2003 | 11:18 AM
Default Re: BFG drag radials or FALKEN Azenis?? (vegan_punk)
Life for a drag radial isnt too long...Tire life is not on the top of the list of manufacturers when it comes to building a tire for traction...you just cant have both...Yes, there are two different versions of the BfG but the better of the two would be the G-Force T/A...
Old May 28, 2003 | 04:23 PM
SergEK's Avatar
Default Re: BFG drag radials or FALKEN Azenis?? (Turbologist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbologist &raquo;</TD></TR><TR><TD CLASS="quote">Life for a drag radial isnt too long...Tire life is not on the top of the list of manufacturers when it comes to building a tire for traction...you just cant have both...Yes, there are two different versions of the BfG but the better of the two would be the G-Force T/A...</TD></TR></TABLE>
Street = Azenis
Drag only = BFG
I raced with my BFG KD's and then with my BFG Drags....world of difference...no more wheel hop....2.0 60's BUT after a year of having them I think they are giving up the ghost....try to keep the drag radials out of the sun when they are not in use.....I think I dried mine up due to them being in the back of my hatch when not at the track. Lesson learned
Also if 90% of the time your cruising/turning/braking with the car on the street the azenis makes much more sense. The BFG is like a rubber donut.....vague feedback and squishy response aka scary at higher speeds on the street. Not a tire I felt comfortable 3 wheeling with
Old May 29, 2003 | 09:04 AM
wuhungsixxx's Avatar
New User
i have gotten ALOT of wheel hop from Azenis probably cause of the stiff sidewalls...best was a 2.2...
BFGs are the obvious choice over the two since thats what it was designed to do(drag)
Old May 29, 2003 | 10:28 AM
QCKGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbologist &raquo;</TD></TR><TR><TD CLASS="quote">I second that...the 555r's are junk....Get the BfGs if you plan on making some serious HP or plan on racing alot...</TD></TR></TABLE>
the 555r's just look nasty but no performance compared to the bfg's
Old May 29, 2003 | 09:46 PM
vegan_punk's Avatar
Default Re: BFG drag radials or FALKEN Azenis?? (QCKGSR)
So for tires for the streets with a turbo civic (I'm trying to get rid of my tires spinning) which tires would be the best for performance, longevity, and price. I have 24" slicks for the track so these would be strickly for the street. By the way how are the bfg's that aren't the G-Force T/A?
Old May 30, 2003 | 12:56 AM
Tofurky's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vegan_punk &raquo;</TD></TR><TR><TD CLASS="quote">By the way how are the bfg's that aren't the G-Force T/A?</TD></TR></TABLE>
not too good for drag racing with your front wheels.
Old May 31, 2003 | 07:31 PM
maxpsi's Avatar
Default Re: BFG drag radials or FALKEN Azenis?? (fastwanabe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe &raquo;</TD></TR><TR><TD CLASS="quote">
2.2? I do that on street tires, WTF?</TD></TR></TABLE>
I pull consistent 2.2 60ft on my street tires also (Falken Ziex 512s). I wouldn't trade them for a fast wearing, soft rubber compound when I can get the same performance out of a cheaper, longer lasting tire through the same manufacturer. Azenis = Overrated
Old May 31, 2003 | 07:41 PM
Civic_95_Si's Avatar
I cut 2.20 on my all season Yokohamas last season. I'll find out this week if Azenis can do any better. I know they're not drag tires, but neither were my Yok's. They seem like great daily driver tires as long as you're not burning them off at every stop sign or AutoX'ing them every weekend.
Old May 31, 2003 | 10:55 PM
BIGTUNA's Avatar
BFG's are made using super soft drag slick compound except they cut grooves in em for some stability in the rain.
Old May 31, 2003 | 11:57 PM
Tofurky's Avatar
Default Re:
be really careful with bfg's in the rain.
but the g-force can grip like crazy
and as far as drag racing goes, falken azenis wheelhop... that's just from what i've seen/experienced though.
Old Jun 1, 2003 | 12:19 AM
Flamenco-T's Avatar
Default Re: Re: (Ruckus138)
to all you guys who's pulling 2.2 on street or azenis, what size tires are you running ?
stan
