rebuilding block ?'s
Old Jul 13, 2001 | 09:36 PM
Darren94ls's Avatar
New User
Default rebuilding block ?'s
hi everyone, i have a 94 ls and i have 123,000 miles and i am going to do ls/vtec and i was wondering what should i do to rebuild the block so its practically brand new. pistons,......? what do u guys recommend and if i use a b16 head is it good to use ITR pistons? any suggestions
thanks for all your help
darren
Old Jul 13, 2001 | 10:51 PM
BoM's Avatar
BoM
Default Re: rebuilding block ?'s (Darren94ls)
if u wanna rebuild ur block soo it feels new, you should get new pistons, rings, and rods...use arp head bolts and rod bolts and new honda bearings...and choose wisely on what ur gonna do.....low compression if u gonna go turbo .... or high if your going allmotor....b16 is a cheaper alternative to ur lsvtec....also have a good shop or person do ur motor....u dont' want to ruin it....
Old Jul 13, 2001 | 10:59 PM
Darren94ls's Avatar
New User
Default Re: rebuilding block ?'s (bommiE)
thanks for reply bommiE- im going to go all motor....so is ITR pistons good w/the b16 head?
any other opinions out there?
Old Jul 15, 2001 | 10:12 AM
VTEC-LesS's Avatar
sounds like a good idea. you may want to do a search on ls/vtec on the boards for more info on that.
good luck and keep us updated with your process.
Old Jul 15, 2001 | 04:53 PM
BoM's Avatar
BoM
Default Re: rebuilding block ?'s (VTEC-LesS)
i dont know about compression numbers with those...but i know its gonna be above 10-1
Old Jul 15, 2001 | 05:32 PM
ndustryalGSR's Avatar
Check out http://crvtec.com. It's for doing a B20 VTEC motor, but the info is similar to your proposed LS/VTEC combo. They have more info than you can shake a stick at.
Civicr2gs5
Dec 15, 2005 02:18 PM
pane93civhb
12
Oct 20, 2004 02:09 PM
compwc18
Mar 7, 2004 10:22 PM
SupaFly_Honda
Oct 3, 2003 05:45 PM
InfamousRS
Jun 7, 2002 08:46 AM
