What springs would you recommend??
I have a 97 civic ex coupe first of all...
Anyways, I want a 2" drop all around, so I dont have to get a camber kit, and I want a decent ride, but I want good handling, I just dont want my fillings shaking out everytime i go over some railroad tracks.
What springs would you recommend, and if you have a pic of the drop they give, please post it.
Thanks!!
Thanks!!
i would go for some h and r race springs or some neuspeed race springs. both give around 2-2.5 drop, a little on the stiff side though.
I will be getting KYB AGX shocks.
About how much will a camber kit cost, and why couldnt a good alignment take care of that.
I am still kinda new to the game, so I dont know a lot about suspension stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonFedHatch »</TD></TR><TR><TD CLASS="quote">eibach Ground Control coilovers on KYB AGX's or GR2's (very affordable) and very nice setup
I have the KYBs and I like them alot.
just take the dudes word for it..anything with a drop of 1 3/4 "..ur going to need a camber kits or ur going down the hiway s like this / \ ..a little neg. camber will be present with any drop..but 2 in. will be too much
H&R Sport Springs
1.75" drop in the front 1.5" in the back, and you will still need a camber kit if you want your tires to wear properly.
Check out this info on spring rates too......
https://honda-tech.com/zerothread?id=512001
Modified by RyanCivic2000 at 1:22 AM 5/27/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deepnite »</TD></TR><TR><TD CLASS="quote">just take the dudes word for it..anything with a drop of 1 3/4 "..ur going to need a camber kits or ur going down the hiway s like this / \ ..a little neg. camber will be present with any drop..but 2 in. will be too much</TD></TR></TABLE>
I had a 2" drop and it only had 1 deg. of camber all the way around. I now have a 3" drop and have no problem with camber wear on my tires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tominos »</TD></TR><TR><TD CLASS="quote">i would go for some h and r race springs or some neuspeed race springs. both give around 2-2.5 drop, a little on the stiff side though.</TD></TR></TABLE>
i have them on tokico 5 ways.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">
H&R Sport Springs
1.5" drop in the front 1.25" in the back, and you will still need a camber kit if you want your tires to wear properly.
https://honda-tech.com/zerothread?id=512001</TD></TR></TABLE>
Correction, its 1.75 front and 1.50 back. Rear washer mod in the back and a good alignment, and no camber kit is needed. But each car is different.
H&R Sport Springs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonFedHatch »</TD></TR><TR><TD CLASS="quote">eibach Ground Control coilovers on KYB AGX's</TD></TR></TABLE>
