Catco cat converter....sucks ass
I have had my Catco cat from Summit on only 1 month and the heat shields are rattling like *CRAZY* (louder by the day it seems). Can the heat shields be removed? What can I do? Thanks in advance
If you did a search ahead of time, you would have known that it is safe to take off the heatshields from the cat. Just don't run over a lot of dry grass.
Does it suck ***? Well, CONGRATS.
problem with the catco cats (got one on the crx) are that the heat shields are spot welded on. So they cannot be easily removed by conveniently unscrewing a few bolts.
Are you sure it is the heat sheilds? It could be the "honeycomb" material breaking off inside the cat, very common in aftermarket hi-flow cats that are cheaply made.
SMSP sells them. Do a search under his name and you will find his contact info. Great customer service buy the way
smsproducts@carolina.rr.com
[Modified by Tbone, 12:53 PM 7/14/2001]
smsproducts@carolina.rr.com[Modified by Tbone, 12:53 PM 7/14/2001]
onyx00
Apr 3, 2002 03:57 PM
