vtec wiring pressure switch, knock sensor
Old May 26, 2003 | 04:25 PM
Lamchop0000's Avatar
Default vtec wiring pressure switch, knock sensor
alright here's the situation
B16A1
90' crx si
obd0 PR3
i know where to wire the vtec to my ECU, but where do they go on the engine?
1)where do i wire the vtec pressure switch? is it that green plug under the vtec seloniod? if so i see 2 wires coming out of it and in that picture it says only 1 wire.
2)where do i wire up the knock sensor, or where is it located?
3)do i just extend the 2nd o2 wire to the ecu?
4)last but not least, the vtec is a simple ecu to solenoid, correct?
i know i sound like a big baby.
and if anybody can post pictures of the knock sensor and vtec pressure switch it will be very helpful.
thanks
Old May 26, 2003 | 04:34 PM
MADEINIRAQ's Avatar
Default Re: vtec wiring pressure switch, knock sensor (lamchop0000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lamchop0000 &raquo;</TD></TR><TR><TD CLASS="quote">alright here's the situation
1)where do i wire the vtec pressure switch? is it that green plug under the vtec seloniod? Yes if so i see 2 wires coming out of it and in that picture it says only 1 wire. other wire is ground.. i think the black one, run the ground to the thermostat housing where the other grounds are
2)where do i wire up the knock sensor, or where is it located? Back of the block up and to the left of the oil filter
3)do i just extend the 2nd o2 wire to the ecu? Yes
4)last but not least, the vtec is a simple ecu to solenoid, correct? yes
Old May 26, 2003 | 06:29 PM
oh fa sho
Old May 26, 2003 | 09:19 PM
James90Teg's Avatar
The vtec pressure switch is the green connector under the vtec solenoid. It has 2 wires because one goes to the ecu and the other goes to a ground anywhere on the engine. Also the knock sensor is a green plug located at the rear of the block underneath the intake manifold. I wired everything but the knock sensor on my b16a and it runs fine without it.
Tight R
Jul 20, 2009 11:00 PM
ahthisguyhere
11
Apr 24, 2006 04:22 AM
Ak_ef9
17
Feb 16, 2006 03:34 AM
mengy007
Sep 6, 2004 03:06 PM
ITR1071
Jan 2, 2003 04:32 PM
