Window Adjustment EK
Hey guys, my damn passenger side window fell off the track in my EK hatch, and Im having a helluva time getting it to line back up. Ive followed the directions in the helms manual, but can't get it to sit where there are no small gaps...has anyone done this and found a trick to get it to sit in there right???
if you are following the helms and it still wont track right, then you need a new regulator(scisors) as yours is bent.
Ive tried ajusting the two tracks that the widow is guided by (as the helms says) and I cant get rid of all the gaps. There is still a small gap at the front of the widow (and around the top a little), but I was wondering if you could adjust the two brackets that hold the window to the sciissors to make that gap go away? Ive tried adjusting it myself and can't seem to get it right!
EDIT: It will roll up and down fine, but it just doesnt seal on the front and the top twoard the front of the car....
You can adjust the tracks, just like the helms says. Follow the helms.
If it still doesnt align, your regulator is bent.
I dont know what else to tell you. They bend.
dan89crxsi
Sep 22, 2006 03:48 AM
