sohc vtec cam
Old May 26, 2003 | 02:34 PM
Dancing is Forbidden's Avatar
Default sohc vtec cam
where is the best place to get a SOHC VTEC cam for a d16z6? Links and companies please!!!!!
Old May 26, 2003 | 03:18 PM
vladd's Avatar
Default Re: sohc vtec cam (EF9_SiR)
imo cams on sohc engines are a waste of money. i was looking at an old super street the other day, they put a cam into a d16z6 which cost about $650 retail price and gained less than 3 hp. that 650 could've been put to better use than that imo.
Old May 26, 2003 | 04:03 PM
OnebadJdmEg6's Avatar
From: being tracked by FAGS Docking PERCENTAGES, GAYFUKS
look for gude cams or web cams good regrinds 200-300 bucks works bad mines was regrinded ruben racing stage 2 w/core for 50bucks that **** haul *** i hung on fender with a 98 bonestock gsr if only that night i wasnt loaded with passengers i'd be happier
Old May 26, 2003 | 04:08 PM
GSR Dave2094's Avatar
Default Re: (OnebadJdmEg6)
I disagree with the theroy of only gaining 3 hp for a cam on a SOHC. I had a stock re-grind from JG in my old del Sol (taht I sold) but I would look into a Gude or ZEX cam. Or you cna get a stock re-grind from JG. A street/strip cam from ZEX can gain up to 12hp.
Good Luck!!
Old May 26, 2003 | 04:57 PM
Ricey McRicerton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OnebadJdmEg6 &raquo;</TD></TR><TR><TD CLASS="quote">look for gude cams or web cams good regrinds 200-300 bucks works bad mines was regrinded ruben racing stage 2 w/core for 50bucks that **** haul *** i hung on fender with a 98 bonestock gsr if only that night i wasnt loaded with passengers i'd be happier </TD></TR></TABLE>
Ummm what???
Old May 26, 2003 | 05:53 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: sohc vtec cam (civicdxtyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdxtyper &raquo;</TD></TR><TR><TD CLASS="quote">imo cams on sohc engines are a waste of money. i was looking at an old super street the other day, they put a cam into a d16z6 which cost about $650 retail price and gained less than 3 hp. that 650 could've been put to better use than that imo.</TD></TR></TABLE>
don't say anything unless you know first hand....
I gained 15 whp from a ZEX 59300 cam with my shot stock bottom end in my D16Z6....I want a new Skunk 2 though
Old May 26, 2003 | 05:55 PM
navin's Avatar
Default Re: sohc vtec cam (Emerika)
also...stop reading Super Street for your tech purposes..
Old May 26, 2003 | 06:58 PM
Dr. Gonzo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">
I gained 15 whp from a ZEX 59300 cam with my shot stock bottom end in my D16Z6....</TD></TR></TABLE>
I've had firsthand experience and will agree there is some hp to be gained with the 59300. I give ZEX a
Old May 26, 2003 | 07:03 PM
SikofFalln's Avatar
Default Re: sohc vtec cam (benji)
I heard zex was good also.
Old May 26, 2003 | 07:48 PM
Eee Pee's Avatar
Default Re: sohc vtec cam (BseriesPWR)
http://www.hadamotorsport.com/...2.htm
Good page for D cams.
Old May 27, 2003 | 07:37 AM
thevtecnician's Avatar
Default Re: sohc vtec cam (Eee Pee)
Skunk 2, peep that cam out, plus, you get a plate showing off the street legality of the cams
Old May 27, 2003 | 09:12 AM
Civic_95_Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by navin &raquo;</TD></TR><TR><TD CLASS="quote">also...stop reading Super Street for your tech purposes.. </TD></TR></TABLE>
ROFL thats funny, but so true.
Old May 27, 2003 | 01:48 PM
vladd's Avatar
Default Re: sohc vtec cam (navin)
i was just using that as an example because i had seen it pretty recently. just looking around on messageboards it seems like people usually don't gain more than around 5 hp from just a cam. i've never seen a before and after dyno of just a cam. usually people put on cam gears and other mods at the same time, and still don't gain very much after all that $. anybody want to prove me wrong?
Old May 27, 2003 | 02:27 PM
Spade's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9_SiR &raquo;</TD></TR><TR><TD CLASS="quote">where is the best place to get a SOHC VTEC cam for a d16z6? Links and companies please!!!!!</TD></TR></TABLE>
http://www.crower.com direct from Crower $325 each for a newly made cam out of a solid core. The price is the same no matter what stage you get.
However, suggest you upgrade your valve springs too if you go for a stage 2 or higher cam.
JBOCRXsiR
Aug 3, 2004 01:19 PM
ShiroX
23
Jul 12, 2004 05:49 PM
743power
Aug 10, 2003 11:43 AM
Lookincrazy
May 8, 2002 10:25 AM
AshlandSi
13
Nov 9, 2001 07:15 AM
