Best all motor street set up?
I'm certain I'll get quite a few replies for this one. Just wanted to get everyody's personal opinion about their most ideal street set up for an all motor car. Street driven, pump gas, reliable and docile enough to lend to your girlfriend(Or BF).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoodgeDc2 »</TD></TR><TR><TD CLASS="quote">jerrys built motor... from import builders in cali... </TD></TR></TABLE>
riiiiiiiiiiiiight.
for a daily driven car i wouldnt go higher then 13:1 cr. Go with some real good cams like JUN 3's or skunk2 stage 2 and reliability shouldnt be much of an issue if its built and tuned right. alot of the motors reliability relies on the tune. dont chince on that
Modified by simple4012 at 8:42 PM 5/26/2003
riiiiiiiiiiiiight.
13-1
89 stroke
84 bore
gsr block
jg or skunk mani
smsp header
70mm tb
hondata
s2s2 cams
portflow or alaniz head work with valvetrain
stock r trans
good reliable 225 or so
89 stroke
84 bore
gsr block
jg or skunk mani
smsp header
70mm tb
hondata
s2s2 cams
stock r trans
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorDC2 »</TD></TR><TR><TD CLASS="quote"> Just wanted to get everyody's personal opinion about their most ideal street set up for an all motor car. Street driven, pump gas, reliable and docile enough to lend to your girlfriend(Or BF). </TD></TR></TABLE>
hmm..most ideal set-up for all motor street car..id say
540 ci Big Block Chevy w/FI
9 to 1 comp
345cc AFR heads
Hyd Roller Cam
back by a Richmond 6sp
oh wait,if your girlfriend dont know how to drive a manual,go with a TH400 with a gear venders overdrive
9 to 1 comp
345cc AFR heads
Hyd Roller Cam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TREVER »</TD></TR><TR><TD CLASS="quote">13-1
89 stroke
84 bore
gsr block
jg or skunk mani
smsp header
70mm tb
hondata
s2s2 cams
stock r trans
This one sounds promising.
89 stroke
84 bore
gsr block
jg or skunk mani
smsp header
70mm tb
hondata
s2s2 cams
stock r trans
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorDC2 »</TD></TR><TR><TD CLASS="quote">Street driven, pump gas, reliable and docile enough to lend to your girlfriend(Or BF). </TD></TR></TABLE>
Why would yu lend your car to your GF? Your just asking to get it totalled or blown up when she fills it up with 87 Octane.
Anyways, ideal street all-motor setup for a puss-***? JDM ITR Motor with some bolt-ons. Real men run racegas
Suprdave
Suprdave
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 »</TD></TR><TR><TD CLASS="quote">
This one sounds promising.</TD></TR></TABLE>
it wont run too well on pump gas w/ 13 to 1s
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Man »</TD></TR><TR><TD CLASS="quote">
Even if he got it tuned?Im gonna be running race gas or lower my compression.
You gotta pull alot of timing to run 13:1. Luckily, alot of the highend pistons(RW, IBspec, etc.) dont need alot of timing for max power.
Suprdave
Suprdave
B18c1 Motor
Golden Eagle Deckplate
Golden Eagle Sleeves
95mm Eagle Stroker Crank
CP 86m 12.5:1 Pistons
Pauter Rods
Golden Eagle OEM Bored Headgasket
ARP Headstuds and bolts
Electric Water Pump
Moroso Dry-Sump Oiling System
B18c1 head with Portflow work, welded chambers, deshrouded, port, polish, valvejob..
Jun IV/Toda D's/ Rocket M25E's Cams (pick!)
TMW 52mm ITB's
JDM ITR Valvecover
Motec M800 Standalone
B16 Tranny
Quaiffe Differential
Quaiffe Ring Gear Set
DSS Stage 3 Axles
2.2L B-series. Should get close to 300whp with proper tuning!
Now that's what I call a street car motor!!!
Want to make it a race car motor? Increase the compression to like 14.5:1 and retune. BOOM! you now have a race motor..lol
That might be a slightly expensive setup. My new setup that im building is slightly more affordable for the college students and family men:
B18c1 Block
Golden Eagle Sleeved
86mm Je pistons
Eagle Rods
LS Crank
Jun IV Cams
Jun Valvesprings
Jun Retainers
Stock GSR Head
Skunk2 Intake Manifold
RPM Services 70mm TB
MSD Fuel Pump
550cc Injectors
STR Fuel Rail
Comptech IceBox
HeaderTech SS 4-1 Header w/ 3" Merge Collector
3" QTEC used along stock civic exhaust
Hondata to tune
Hopeing to make around 225 w/ a stock head, then later get my other head ported and swap heads and see how much extra power I can make.
Pauter Rods
Electric Water Pump
TMW 52mm ITB's
JDM ITR Valvecover
B16 Tranny
DSS Stage 3 Axles
B18c1 Block
86mm Je pistons
Eagle Rods
LS Crank
Jun IV Cams
Jun Valvesprings
Jun Retainers
Stock GSR Head
MSD Fuel Pump
550cc Injectors
STR Fuel Rail
Comptech IceBox
Hondata to tune
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxBoost »</TD></TR><TR><TD CLASS="quote">B18c1 Motor
Pauter Rods
Electric Water Pump
TMW 52mm ITB's
JDM ITR Valvecover
B16 Tranny
DSS Stage 3 Axles
Want to make it a race car motor? Increase the compression to like 14.5:1 and retune. BOOM! you now have a race motor..lol</TD></TR></TABLE>
god damm, that's what i call a set up. just be ready to put your plastic on the line, it's gonna cost mucho bucks!
Pauter Rods
Electric Water Pump
TMW 52mm ITB's
JDM ITR Valvecover
B16 Tranny
DSS Stage 3 Axles
your kidding right??they stated already it isnt a motor for daily driving
The following set-up is good for all-around purposes. It will not cost you a summer's worth of pay checks, and will be reliable. I dont know what kind of power you are looking to make but, here ya go.
B18C1
11.0:1 Cr pistons(Je, Ross, or anything that you prefer)
Crower Rods ( Again, something similar, even a shot-peened stock-rod)
ARP Studs
P72 Head
Toda B's, Skunk Stage 2's(Something smaller will work too...You can cut a corner with JDM CTR Cams)
Double Valve Springs, Retainers (Crower, Toda, anyone respectable. Stock Type-R's even.)
No porting, but the ports should be cleaned up any. (Machine work optional)
Stock Intake manifold (ported/ port matched to 60/62 mm Throttle Body(Erick's,BBK,TypeR)
AEM CAI
Header Tech Header ( DC 4-1, or JDM style 4-1)
Lightened FlyWheel (Not too light), Stage 2/3 ACT
Stock Ignition
AEM FPR, (Venom In-Tank Fuel Pump, or BBK)
Possibly some Prelude Vtec Injectors...(270 cc I think)
Hondata ( Not sure which model. Research this part...)
2.5" Exhaust with removable test pipe for race day(Apexi N1, Greddy Evo, something similar)
Skunk2 Drag springs, 24-way Koni's, or Adjustable Tokico's
Nitto 555 R's
If it is in the budget, balancing the rotating assembly is a plus as well. Again, this set-up is a very mild street set-up that will not yield incredible HP numbers but will be quick. It will also be extremely reliable. The above set up gives you some options so that you can tailor it to your budget. Whichever way you go, best of luck...
B18C1
ARP Studs
P72 Head
AEM CAI
Stock Ignition
Nitto 555 R's
ITR motor 11.5-12.0:1 comp (CTR pistons w/thicker headgasket)
SMSP exhaust system (incl header $$$)
190lph pump w/ 310's
Hondata or AEM for tuning
Toda valve springs, cam gears, flywheel, Spec B's, timing belt
Clay the motor, tune it and enjoy some nice street gains without having to rip the motor apart ($$$$) I would guesstimate that with tuning 200-215whp should be about right for this setup while being street friendly and not too much dough while keeping the essecence of the ITR motor intact.
For a fully built motor there will be many opinions and methods.....choose yours and stick with it.
Pauter Rods
Electric Water Pump
TMW 52mm ITB's
JDM ITR Valvecover
B16 Tranny
DSS Stage 3 Axles
wow 12.5 compression and 300whp, good stuff, i gotta save this in my favorites
Pauter Rods
Electric Water Pump
TMW 52mm ITB's
JDM ITR Valvecover
B16 Tranny
DSS Stage 3 Axles
Guest
Posts: n/a
I vote for TREVORS old setup that made like 190 WHP all motor and like 280+ with the push of 1 little button. 11.80's?? with his 6'5" 250 pound but in it. Crazy fast.
It was reliable for the longest time, and got rediculous gas mileage.
Loan it to the girlfriend (Which is wishful thinking for alot of the internet dorks on the internet, lol) you just disconnect the NOS button...
Perfect setup.
Jeff
Perfect setup.
Jeff
Not the best ...but here is my budget setup currently being built:
B18C1 Block
OS. JDM ITR pistons w/ 2 layer head gasket (CR around 12:1)
micropolish crank
port/polished GSR head w/ valve job
ITR cams
dual valve springs/tit retainers
Skunk2 IM
270cc Injectors
Hondata s200
62mm TB
DC 4-1/exhaust/AEM CAI
ITR tranny
ACT pro-lite flywheel
RPS pressure plate
ACT clutch
B18C1 Block
micropolish crank
ITR cams
Skunk2 IM
270cc Injectors
Hondata s200
62mm TB
ITR tranny
RPS pressure plate
ACT clutch
Pauter Rods
Electric Water Pump
TMW 52mm ITB's
JDM ITR Valvecover
B16 Tranny
DSS Stage 3 Axles
In a fairytale land...I don't think he asked what would you do if money grew out of your ***.
Pauter Rods
Electric Water Pump
TMW 52mm ITB's
JDM ITR Valvecover
B16 Tranny
DSS Stage 3 Axles
