Master Cylinder rusted? Change out? What kind? Help.
Old May 26, 2003 | 08:35 AM
RacerBoy's Avatar
Default Master Cylinder rusted? Change out? What kind? Help.
My master cylinder is pretty much rusted all below the brake booster. Should I change this soon. I might be changing my intake manifold and alternator soon so I might as well do this too. Off what car can I get one? Just get a regular CRX one? I'm running a stock one with an integra brake booster currently.
Old May 26, 2003 | 08:36 AM
crexer's Avatar
Default Re: Master Cylinder rusted? Change out? What kind? Help. (RacerBoy)
I think the 89 prelude si one is a little better than the stock crx one; its a direct fit
Old May 26, 2003 | 09:29 AM
Vinceg99's Avatar
Default Re: Master Cylinder rusted? Change out? What kind? Help. (crexer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer &raquo;</TD></TR><TR><TD CLASS="quote">I think the 89 prelude si one is a little better than the stock crx one; its a direct fit</TD></TR></TABLE>
Its not a direct fit you have to bend the lines a little to have them line up correctly. The 90-91 Civic EX is the one that is a direct fit but also costs more money than the Prelude one does.
Old May 26, 2003 | 10:41 AM
89civicdx's Avatar
Default Re: Master Cylinder rusted? Change out? What kind? Help. (Vinceg99)
get the 89 prelude
Old May 26, 2003 | 11:31 AM
RacerBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vinceg99 &raquo;</TD></TR><TR><TD CLASS="quote">
What are the exact procedures with this? Get a junkyard one?
Old May 26, 2003 | 04:26 PM
RacerBoy's Avatar
bump
Old May 26, 2003 | 05:16 PM
audioroach's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacerBoy &raquo;</TD></TR><TR><TD CLASS="quote">
What are the exact procedures with this? Get a junkyard one?</TD></TR></TABLE>
I would never place my life in the hands of a boneyard master cylinder...
I strongly suggest that you not do the same...get it from an autoparts store.
Old May 26, 2003 | 05:21 PM
SteveeeO's Avatar
Default Re: Master Cylinder rusted? Change out? What kind? Help. (audioroach)
89 prelude or 90-91 civic EX
Old May 26, 2003 | 10:55 PM
Vinceg99's Avatar
Well the procedure is actually extemely easy. Unbolt the lines on your old M/C unbolt the M/C itself pull it off bolt the new one on and reattach the lines. I am however just talking about the M/C and NOT the brake booster to take that out is a bit more work like having to climb under the dash to take the 4 nuts that hold it in. And as for what kind of booster and from what car I am not sure I have heard people using all sorts of different ones but until I try it myself I wouldnt be able to recommend any kind of booster but the 90-91 Civic EX M/C is a direct bolt in and the 89 Prelude you have to bend the lines a bit. Not too hard to do either so if your looking to save money go the Prelude way. I believe Driven did a very nice write up on the install of the Prelude one but I cant find it right now.
Antinull
20
Jun 14, 2012 06:15 PM
djnikko
12
Dec 8, 2006 12:50 PM
Rob.
32
Jun 29, 2005 08:18 PM
K-Drum
Jul 17, 2004 09:24 AM
bluecrx
14
Feb 25, 2003 04:18 PM
