KYB AGX vs OEM struts for Ground Control
Old May 26, 2003 | 07:49 AM
DC5_R's Avatar
Default KYB AGX vs OEM struts for Ground Control
Im on Ground Control with OEM struts on my 5th gen right now. Im planing to get some AGX for my GCs.
Im worried about the O-ring( rubber rings that came with the GC package) from my OEM struts. Will it still be reusable when I slide them in in the AGX?
thanks!
Old May 26, 2003 | 08:39 AM
Gennady's Avatar
New User
Not sure what O-ring your talking about.
Old May 26, 2003 | 08:42 AM
iam7head's Avatar
Default Re: (Wont be beat)
if the rubber ring is not beaten to hell, yes
Old May 26, 2003 | 04:05 PM
DC5_R's Avatar
Default Re: (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">if the rubber ring is not beaten to hell, yes</TD></TR></TABLE>
If the rubber ring is beaten, is there any other way to make the sleeves in the strut stay in place and still isolate the noise? Any remedy to the situation without calling GC?
To those who doesn't know . The O-ring is that rubbber ring you slide inside the strut before you put in coilover sleeve. It helps the sleeve stay in place and isolates any metal to metal noise it can cause.
Is the geometry of most aftermarket struts the same as OEM struts? Or are some way fatter?
Old May 26, 2003 | 04:36 PM
iam7head's Avatar
Default Re: (Inspire95)
yeah..that's it.
get some fuel line or heavy duty hose and put a piece of metal wires inside and wrap around it
Understeer
Dec 30, 2007 08:13 PM
integrawow
Suspension & Brakes
Jul 28, 2007 07:44 PM
central_driver
13
Apr 3, 2006 09:57 PM
Isaac
Apr 19, 2002 09:08 AM
