whats the deal with the trim sizes ....
Old May 26, 2003 | 07:35 AM
respectblades's Avatar
Default whats the deal with the trim sizes ....
ok i'm trying to figure out what is meant by .48 trim and .63 trim and so on
what does this mean
Old May 26, 2003 | 02:41 PM
Quick 200k Mile Motor's Avatar
Default Re: whats the deal with the trim sizes .... (respectblades)
Those you mentioned are not trim numbers.
They are for the a/r [the size of the turbine housing (exhaust side of the turbo)] in the T3 family.
.48 smallest
.63 mid
.82 largest
Trim is the wheel size for either the compressor or turbine side.
Old May 26, 2003 | 02:44 PM
Killa's Avatar
Default Re: whats the deal with the trim sizes .... (Quick 200k Mile Motor)
.36, .48, .63 and .82 are all T3 exhaust housing A/R's. They belong to the T3 family of turbochargers.
Trims the relationship of the inducer to the excuder and squared.
The smallest T3 exhaust a/r is a .36 and not a .48 like it was mentioned above.
Paul
Old May 26, 2003 | 04:21 PM
Default Re: whats the deal with the trim sizes .... (HondaKilla)
thanks for the correction
Old May 28, 2003 | 11:47 AM
ok so now my next question is ....
how do you determine which size is best for a particular application...
and whats needed to run certain sizes
Old May 28, 2003 | 11:53 AM
I Like Boost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by respectblades &raquo;</TD></TR><TR><TD CLASS="quote">ok so now my next question is ....
and whats needed to run certain sizes</TD></TR></TABLE>
Well just list your setup, what type of driving (street, drag, auto-x) how much power you want to make, and your budget. We will be able to narrow it down for you.
Old Jun 5, 2003 | 06:48 AM
-Trinitron-'s Avatar
Default Re: whats the deal with the trim sizes .... (IMPULSE B18C-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMPULSE B18C-T &raquo;</TD></TR><TR><TD CLASS="quote">
Well just list your setup, what type of driving (street, drag, auto-x) how much power you want to make, and your budget. We will be able to narrow it down for you.</TD></TR></TABLE>
T3/04 B16 (Maybe LSVTEC), looking for 250-275hp on a semi-street/drag. What trim level and a/r ratio should I be looking for. I would sacrifice a little lag on the low end for big power up top.
Old Jun 5, 2003 | 07:37 AM
94TealGSR's Avatar
I was just about to make a thread just like this. Good thing I saw this one...
I bought a turbo yesterday for my B18C1 setup:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEAPTURBOdotCOM &raquo;</TD></TR><TR><TD CLASS="quote">Freshly rebuilt turbonetics t3/to4b s-trim w/ .63 a/r stg 1 clipped.</TD></TR></TABLE>
So, what does "s-trim" mean?
What are the stages of the wheels?
Old Jun 5, 2003 | 08:02 AM
red_sir's Avatar
Default Re: whats the deal with the trim sizes .... (94TealGSR)
https://honda-tech.com/zerothread?id=523242
Old Jun 5, 2003 | 08:14 AM
94TealGSR's Avatar
Default Re: whats the deal with the trim sizes .... (red_sir)
Hm, that post is awesome. Very informative...
So here are a few facts on my turbo:
S trim (37 lb/min)
Stage 1 (small -- most common turbine on junkyard turbos)
But what does 37lb/min mean?
Old Jun 5, 2003 | 08:55 AM
EE_Chris's Avatar
37lb/min is an airflow rate.
Old Jun 5, 2003 | 09:05 AM
Mikeyslude's Avatar
http://www.majesticturbo.com has a formula you can use to determine what you need.
civichbsi1590
Feb 23, 2011 02:12 PM
dustinz_em1
Nov 25, 2007 05:41 AM
Boostage
Sep 6, 2007 11:35 AM
backspin88
Jun 17, 2005 08:20 PM
NOSED_CRX_VTEC
Oct 31, 2003 09:14 AM
