B18A1 distributor... same cap as d16a6? same distributor?
Old May 26, 2003 | 07:22 AM
91civicDXdude's Avatar
Default B18A1 distributor... same cap as d16a6? same distributor?
Just what the title says. I have a b18A1 that im swapping in to my 91 civic, i have an MSD blaster cap & coil for a d16a6 distributor, will it work on the b18a1? do they have the same distributors since they are both obd0?
Also, if they arent the same, is the wiring the same, because i have the b18a1 distributor, but the plug has been hacked off, wondering if i could use a plug from a d16a6?
Old May 26, 2003 | 08:03 AM
wickedEFguy's Avatar
Default Re: B18A1 distributor... same cap as d16a6? same distributor? (91civicDXdude)
I had a LS dizzy on D16 and it worked just fine, I don't see why the same setup wouldn't work on your motor
Old May 26, 2003 | 09:25 AM
91civicEX's Avatar
you would have to use the d16 plug anyway because it would have to connect to your harness. just match up the colors and it should work.
rhdins
May 7, 2019 06:37 AM
Street_sleeper
Oct 15, 2011 05:47 PM
99sibluehatchwitb16
11
Jan 25, 2006 06:49 PM
