Camber Kit cheapest where to buy and which one
Old May 26, 2003 | 05:58 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Camber Kit cheapest where to buy and which one
I've heard a lot and I only want to spend 100 or less since I am a college student
ingalls is probably what i want to get but it is only 130 for the front
any ideas
Old May 26, 2003 | 07:00 AM
GSRSNATCH's Avatar
Hey I got a spc ball joint style camber kit I will sell you.It was on the car for exactly 61 miles unti some jack@$$ rearended me.I will take 100 bucks for it plus shipping.Email me for pics shannontaylor@comcast.net.Oh yeah its for a 88-91 civic/crx
Old May 26, 2003 | 07:27 AM
SeaBass's Avatar
From: Clueless like Shaggy n Scooby before commercial, break
Default Re:
um, might want to check Tirerack.com.
Probably not be the cheapest though...
Old May 26, 2003 | 10:14 AM
bryant's Avatar
Default Re: Camber Kit cheapest where to buy and which one (MugenHonda)
Pick up those SPC's from the guy above. Those are really nice and way better then that ingalles stuff.
Old May 26, 2003 | 10:24 AM
91hatchcivic's Avatar
Default Re: Camber Kit cheapest where to buy and which one (Bryant)
hey , not to threadjack, but if you dont buy them from him, ill take them, i discovered i need a camber kit,
Old May 26, 2003 | 10:26 AM
91sihatchback
Guest
Posts: n/a
you only need a camber kit if you are dropping your car extremely low and you have 18 inch rims....if you have 16's with bigger tires and you dropped it an inch or 2.5 then you should be fine i dont know what you guys are talking about
Old May 26, 2003 | 10:52 AM
b16_madman's Avatar
Default Re: (91sihatchback)
i am droppin my car 2.25 front 2 back with 15" ls integra wheels...i still might get a set for the front to do it right....
Old May 26, 2003 | 12:33 PM
escocrx's Avatar
Default Re:
if you dont have camber issues on a honda thats dropped. then your not dropped. your high riding thinking your dropped. cuz no matter what u drop it 2.5 and it will have camber issues guaranteed.
on my ride going from 14" stock si's with insane wear on the inside, to 17x7 rims fixed it somewhat. giving the ground more surface space to lean on. but it still has wear issues.
i happen to rather spend more and get better than save a few and git ****.
those camber kits where the balljoint is the adjustable part, jus kick yourself in the jaw. they are crap. not a single brand have i seen last 20k miles if at 10k miles
but again i go for quality and durability over cheap price.
A-J's Racing has some nice upper control arms for ek's with adjustable camber. Very nice construction but very pricey and pain staking to adjust almost a grand for the set installed. around 720 shipped. AJ does not make em, they are imported from japan and u can buy them for like 400 bux over there. but of course since they are imported people seem to TAX ALOT.
http://www.aj-racing.com
good site. seem to tax alot to get ****. but i rather pay more and git what i want. than pay less and get less.
but hey. at least u can go through like 5 sets of those cheapy camber kits they make b4 spending the amount to get a set up quality upper control arms.
Old May 26, 2003 | 03:16 PM
xci_ed6's Avatar
Default Re: Re: (escocrx)
I got an ingalls style off ebay for $77 shipped, fits good minimal trimming of the control arm required for setting closest to stock (just square off the corners, i did with a hacksaw with the control arm still on the car). I havn't tried adjusting it yet, but it appears easy enough.
-Dustin
Old May 26, 2003 | 03:50 PM
90civichbsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91sihatchback &raquo;</TD></TR><TR><TD CLASS="quote">you only need a camber kit if you are dropping your car extremely low and you have 18 inch rims....if you have 16's with bigger tires and you dropped it an inch or 2.5 then you should be fine i dont know what you guys are talking about</TD></TR></TABLE>
that is if you like your camber to be 3 degrees off
Old May 26, 2003 | 04:16 PM
jc836's Avatar
You will need kits for the car if you drop over 1.5". The spec for many Hondas is 0 degrees +/-1 degree. For each 1" of drop the Camber will go negative by ~.84 degrees. Do the math and you will soon see that kits are usually needed. Both of my cars have them on all 4 corners in one form or another (SPC and Ingalls). Rim size has little to do with it as it is the angle that the upper arm is at after lowering that is a key here. Take a look at both the Ingalls and SPC websites and read the articles they have. The brand you buy is important up to a point. I personally like the way the SPC sliding ball joints work on the front of the Prelude while I have Ingalls 3571 on the rear of that car. Our CRX Si has SPC 84955 kits on the front and shims in the rear for Improved Touring race use. I will add that both Ingalls and SPC have really good control arm products that you can use as well.
My source for Camber kits is Ultra Performance in Tucson-great to deal with and give great service and pricing.
If you are concerned about ball joint wear-the SPC kit is first rate and should last a very long time-the Prelude has much more than 10k on its set, including track days.
LAST thing here-Get the car aligned BEFORE you buy any parts.
Old May 27, 2003 | 01:56 AM
MugenHonda's Avatar
Default Re: Camber Kit cheapest where to buy and which one (jc836)
should i align the car before i put on my camber kit?
because a lot of places don't do alignment on lowered cars
thanks
Old May 27, 2003 | 02:03 AM
MugenHonda's Avatar
Also
what exactly do I need for the rears.
Everybody tells me to buy shims, so do I just use washers?
Some camber kits I see look like a long pencil for the rears.
Old May 27, 2003 | 04:32 AM
FR-MOB: ThE bEe GuY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">should i align the car before i put on my camber kit?
thanks
Align the car After you put the camber kit on. Look around, theres places that will do lowered cars. Its not that much harder on a lowered car, theyre just lazy and dont wanna screw with it, or dont wanna try and get it up on the lift.
B_SISCO409
Jul 12, 2010 08:57 PM
sloweredcivic
Sep 8, 2005 07:43 PM
jArceo
Mar 21, 2005 07:22 PM
LostCRX
Feb 24, 2005 08:15 PM
LS Teg
May 10, 2002 10:18 AM
