Project Nitrous D16Y8
Old May 26, 2003 | 12:20 AM
RyanEJ8's Avatar
Default Project Nitrous D16Y8
I decided for my 1000th post I would share my shortblock build project and some pics. I am building a D16Y8 shortblock to withstand a 125 shot of ZEX.
So far my mods are: AEM CAI, DC Sports 4-1, Tanabe Exhaust, Testpipe, AEM Cam Gear, AEM Fuel Rail, AEM Adj. FPR, AEM Fuel Filter, Holley 255lph HP fuel pump, P28 OBDII to I conversion, ACT Street Disc and HD PP.
Suspension consists of: H&R Sport Springs, Tokico Blues, Camber Kit
I picked up a spare Y8 shortblock to work on while I drive my other one. I stripped it down and sent it off to have all the machine work done. Hot tanked, bored/honed block, polished crank, all new ACL bearings and OEM gaskets. I will be doing the assembly myself.
Here are my new SRP Pistons and Eagle Rods. The compression ratio will be approx. 10.5:1
and the D16Y8 block....
.020 overbore
The underdog........
The crankshaft all polished up, still in wrap...
A Zex .043 jet will be used for 100 shot and a .052 for 125 shot. Fuel enrichment will be provided by 450cc DSM's tuned by my Hondata S200. Some of my other new upgrades are going to be a MSD 6A, ARP Head Studs, and a Golden Eagle block guard. The motor should be in and running by the end of this summer and I should have the 125 shot tuned and run at the track by December.
Sorry 56k, I forgot to post a warning in the title.
Modified by RyanCivic2000 at 1:08 PM 5/26/2003
Old May 26, 2003 | 12:22 AM
Unsung's Avatar
Default Re: Project Nitrous D16Y8 (RyanCivic2000)
very nice setup. I don't mind nitrous setups as long as they are correctly done, and not used like stunna's Good work
Old May 26, 2003 | 12:24 AM
Chris y0!'s Avatar
nice work.
get some new wheels and you're set
Old May 26, 2003 | 12:25 AM
underrated99si's Avatar
Default Re: Project Nitrous D16Y8 (Unsung EM1)
I want to see the #'s on this set up sounds good
Old May 26, 2003 | 12:28 AM
RyanEJ8's Avatar
Default Re: Project Nitrous D16Y8 (underrated99si)
Thanks for comments. I will post the dyno sheets once I have them. It won't be for a few months though, I need to save some money for MSD and dyno time still.
Old May 26, 2003 | 01:06 AM
RyanEJ8's Avatar
I'll also take nicer pics when everythings out of it's wrapping and post them, and then once I have it together.
I'm estimating 230-250whp. Sound about right?
Old May 26, 2003 | 01:17 AM
Mista Bone's Avatar
D Tranny Guru
ryan, take baby steps.
Rich while spraying = safe.
10 BTDC at 50psi............
Old May 26, 2003 | 01:21 AM
RyanEJ8's Avatar
Default Re: Project Nitrous D16Y8 (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">10 BTDC at 50psi............</TD></TR></TABLE>
On 125 shot? I planned on starting with the 100 shot, tuning, and then going to 125 shot, and tune again. I am keeping my other Y8 shortblock for a spare, in case something goes wrong.
Old May 26, 2003 | 02:22 AM
97hb's Avatar
Me likes . So your hondata is going to take care of the fuel and not the zex box?
Old May 26, 2003 | 07:52 AM
RyanEJ8's Avatar
Default Re: Project Nitrous D16Y8 (97hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97hb &raquo;</TD></TR><TR><TD CLASS="quote">Me likes . So your hondata is going to take care of the fuel and not the zex box?</TD></TR></TABLE>
That is the plan. However, I don't think it is possible to remove the vac line from the regulator. I don't think the Zex box can work without it. If that is true, I may use a jetting that gives a very small fuel pressure increase.
Old May 26, 2003 | 08:10 AM
USDMMARK's Avatar
ryan, love the car, love the motor, good luck, don't know what else to say cuz i just woke up but goood luck to you, can't wait to see you at the track again with that monster
peace
Old May 26, 2003 | 08:38 AM
Mr. Thunderlips's Avatar
Anything D-series to me gets a
Old May 26, 2003 | 10:02 AM
RyanEJ8's Avatar
Anyone else use the Hondata nitrous control yet?
Old May 26, 2003 | 10:03 AM
BillWalton1
Guest
Posts: n/a
15's here you come
Old May 26, 2003 | 10:05 AM
RyanEJ8's Avatar
Default Re: Project Nitrous D16Y8 (BillWalton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BillWalton &raquo;</TD></TR><TR><TD CLASS="quote">15's here you come </TD></TR></TABLE>
Considering I already went 14.2 with a 75 shot on streets. Slicks would have landed a 13.9 or better, this all in a full interior coupe.
Old May 26, 2003 | 10:08 AM
joe_bocc's Avatar
Are your SRP pistons special?
I ask this because when I asked a few shops that sell SRP pistons if they would be OK for nitrous, they said that pistons do not handle nitrous well.
Old May 26, 2003 | 10:12 AM
RyanEJ8's Avatar
Default Re: Project Nitrous D16Y8 (joe_bocc)
I haven't heard that. I got them from ben@importparts and he said they would be fine for a nitrous application. I also spoke with Alan at JE who said they are perfectly suitable for nitrous.
Old May 26, 2003 | 11:22 AM
RyanEJ8's Avatar
Forgot to mention, the engine build including machine work and the spare block and crank totaled $1495 (much cheaper than a swap for someone on a budget like me, and more fun too.)
The fuel, ignition, and tuning will total $840. Including the fuel pump I already got for $125 it would be $965.
I got the Zex kit for $485, so all together 125 shot on a D16 cost $2945 (Less than a B18C swap and about 100whp more. )
Old May 26, 2003 | 11:33 AM
Team 4's Avatar
Love the D. SRP's are fine, as they are just shelf stocked JE's.
Old May 26, 2003 | 12:48 PM
RyanEJ8's Avatar
Default Re: Project Nitrous D16Y8 (REVHARD_EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REVHARD_EF &raquo;</TD></TR><TR><TD CLASS="quote">Love the D. SRP's are fine, as they are just shelf stocked JE's.</TD></TR></TABLE>
thanks
Old May 26, 2003 | 01:03 PM
veganej's Avatar
love the set up, same engine as i. Hope to see some numbers soon.
Old May 26, 2003 | 01:58 PM
MAD ITR 55's Avatar
Have you seen that new NX direct port system with the fuel rail included?That looks like it would be a cool setup for you.
Old May 26, 2003 | 03:17 PM
RyanEJ8's Avatar
Default Re: (V8s2shame)
Yes, it is a very nice looking kit, but this was cheaper. I was going nitrous route because it was cheaper than a turbo or swap.
Old May 26, 2003 | 03:22 PM
vladd's Avatar
nice have you ever considered turboing the built block instead of nitrous? i think turbo would be more fun just because it's always available, while you always have to refill nitrous. either way, nice engine
Old May 26, 2003 | 03:27 PM
RyanEJ8's Avatar
Default Re: Project Nitrous D16Y8 (civicdxtyper)
Thanks for compliments everyone, I think turbo setups are nice, but while I am still attending college, building a nitrous setup was cheaper and more practical. When I am done with school in 2 years I plan on starting a turbo project with a different car, and keep this one for my daily driver.
