FYI, So how much ground clearance is there on a 98 Spec ITR JDM 4-1 Header?
Old May 25, 2003 | 10:57 PM
SMSP's Avatar
Default FYI, So how much ground clearance is there on a 98 Spec ITR JDM 4-1 Header?
I was doing a comparison between my new ITR header and the JDM ITR 4-1 header with respect to ground clearance. So here are some pics of the JDM ITR header installed on my jig.
Old May 25, 2003 | 11:04 PM
MugenFG360's Avatar
Default Re: FYI, So how much ground clearance is there on a 98 Spec ITR JDM 4-1 Header? (SMSP)
how come the jdm itr header looks like a pretty good fit?
Old May 25, 2003 | 11:16 PM
SMSP's Avatar
Default Re: FYI, So how much ground clearance is there on a 98 Spec ITR JDM 4-1 Header? (MugenFG360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenFG360 &raquo;</TD></TR><TR><TD CLASS="quote">how come the jdm itr header looks like a pretty good fit?</TD></TR></TABLE>
Not sure what you mean???
But it fits well because it is a Honda OEM piece and it has the best ground clearance of any 4-1 header since the tubes are staggered and lay within each other.
Old May 25, 2003 | 11:36 PM
Nameless RB26's Avatar
Is the "jig" what you test fit your stuff on?
Old May 25, 2003 | 11:59 PM
Aaron M's Avatar
Default Re: FYI, So how much ground clearance is there on a 98 Spec ITR JDM 4-1 Header? (Nameless EJ6)
cool
OT: you know...high quality digi cams are pretty cheap these days
Old May 26, 2003 | 04:05 AM
SMSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless EJ6 &raquo;</TD></TR><TR><TD CLASS="quote">Is the "jig" what you test fit your stuff on? </TD></TR></TABLE>
It's what I use to build a piece. You'll notice the lack of block material in some shots.
Old May 26, 2003 | 06:04 AM
SMSP's Avatar
Default Re: FYI, So how much ground clearance is there on a 98 Spec ITR JDM 4-1 Header? (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">
You should see his vintage video camera.</TD></TR></TABLE>
What's wrong with my pictures?
Old May 26, 2003 | 06:13 AM
.RJ's Avatar
.RJ
Old May 26, 2003 | 07:10 AM
sneakychaos's Avatar
Default Re: FYI, So how much ground clearance is there on a 98 Spec ITR JDM 4-1 Header? (.RJ)
RJ put the crayons down and step away from the computer.
Old May 26, 2003 | 08:10 AM
baonest1's Avatar
Default Re: FYI, So how much ground clearance is there on a 98 Spec ITR JDM 4-1 Header? (sneakychaos)
ooooh, so thats how it should look when installed on the motor..
i beleive mine drops a bit down. i dont have the JDM bracket thing to hook up to the block.
Old May 26, 2003 | 08:16 AM
SMSP's Avatar
Default Re: FYI, So how much ground clearance is there on a 98 Spec ITR JDM 4-1 Header? (baonest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest &raquo;</TD></TR><TR><TD CLASS="quote">ooooh, so thats how it should look when installed on the motor..
i beleive mine drops a bit down. i dont have the JDM bracket thing to hook up to the block. </TD></TR></TABLE>
The bracket won't keep it from dropping down. The piece is very stiff as is. Plus I've seen alot of the brackets crack over time.
Old May 26, 2003 | 10:26 AM
MugenFG360's Avatar
too bad it gets damaged too easily still
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">
But it fits well because it is a Honda OEM piece and it has the best ground clearance of any 4-1 header since the tubes are staggered and lay within each other.</TD></TR></TABLE>
dumafit
Northern California (Sales)
May 19, 2011 11:03 AM
si90rex
Welding / Fabrication
Feb 21, 2007 05:41 AM
b19coupe
Sep 10, 2006 11:59 AM
siblue_gzer
Jul 22, 2006 08:06 PM
