What Year Suspension Will Fit On an EG??
Old May 25, 2003 | 08:06 PM
leprechan117's Avatar
Default What Year Suspension Will Fit On an EG??
ok, im looking to get some apexi n1 coilovers, and for some reason the 92-95 model is $200 more than the others. is it because of the rear lca set up? do any other years suspensions bolt right up, or which will go on with integra lca's?? thanks a lot.
Old May 25, 2003 | 08:10 PM
boostsohfast's Avatar
Default Re: What Year Suspension Will Fit On an EG?? (leprechan117)
the rear lca's for the integra will work on an EG without any problems. I know because I have them. You even get to use the nice factory sway bar that bolts right into them.
Old May 26, 2003 | 07:52 AM
Default Re: What Year Suspension Will Fit On an EG?? (boostsohfast)
yeah i know theyll fit, but then do i get 94+ integra coil overs??
Old May 26, 2003 | 09:30 AM
you can if you want, but you don't have to. They will work fine.
Old May 26, 2003 | 09:33 AM
CXHatchback's Avatar
yeah, the teg ones will bolt right up. And the 96-00 civic ones will work with slight mods to your rear lcas.
eg4metodrive
11
Feb 17, 2006 03:26 PM
92 CIVIC HATCH VX
Nov 29, 2004 06:21 PM
aira
Apr 8, 2003 10:24 PM
