rear sway bar for my eg
Old May 25, 2003 | 07:06 PM
95integragsr1984's Avatar
Default rear sway bar for my eg
i got a rear gsr sway bar and want to install it on my 94 civic cx... theres no holes for it though... how do you guys make this work.. i seen it on toms list of mods.also what about the front.. what kinda frotn sway bar should i get and what will i need to install it?thanks,Randy
Old May 25, 2003 | 07:14 PM
VTEC-DA's Avatar
Default Re: rear sway bar for my eg (95integragsr1984)
You will need to drill holes for it. What kind of reinforcement kit are you using?
Old May 25, 2003 | 07:15 PM
Eg6LazyPt's Avatar
You can get some rear gsr LCA's. Since the sway is from that car, those control arms have the holes made for that sway. Then a Beaks kit for the bolts and brakets would work nice. Unless you feel crazy and wanna just drill the holes you can!
Old May 25, 2003 | 07:17 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
You'll need Civic EX Sedan or Integra LCAs.
Stock 92-95 Si/EX front swaybar is nice. So is the GSR. Pretty sure your LCAs won't have the holes in front, either.
Old May 25, 2003 | 08:21 PM
elwood's Avatar
Default Re: rear sway bar for my eg (SkyeC)
Front Swaybar Size
ex/si: 19mm
eg6: 21mm
gsr: 24mm
Rear Swaybar Size
ex/si: 14mm
eg6: 14mm
gsr: 14mm
Front Swaybar
If you are putting a front swaybar on any 92-95 civic (excluding ex/si)
you will need lower conrol arms from a integra, del sol, or ex/si civic.
Rear Swaybar
If you are putting a rear swaybar on any 92-95 civic (excluding 4dr ex)
you will need rear control arms from a integra, del sol, or a 4dr ex.
Beaks Kit
You do not need the beaks kit for the 14mm rear swaybars because they
should have the brackets on them that were made for the indents in your
frame. The type r had a flat rear frame, this is why you need the beaks kit.
Beaks kit on a civic/integra
Old May 25, 2003 | 08:46 PM
GoT HaTcH's Avatar
Default Re: rear sway bar for my eg (d15dude)
thanks for the helpful info d15dude
Old May 25, 2003 | 09:07 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15dude &raquo;</TD></TR><TR><TD CLASS="quote">[Rear SwaybarYou do not need the beaks kit for the 14mm rear swaybars because they
frame. The type r had a flat rear frame, this is why you need the beaks kit.</TD></TR></TABLE>
Correct. This is a 13mm LS rear.
Old May 25, 2003 | 09:15 PM
elwood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkyeC &raquo;</TD></TR><TR><TD CLASS="quote">This is a 13mm LS rear.</TD></TR></TABLE>
Are you positive? So, the gsr and ls are different?
Anyways, I am wondering if you could use that bracket from the ls/gsr
on the ITR bar? It looks better than the beaks kit and could
be cheaper now that the beaks kit is $60.
Old May 25, 2003 | 09:18 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
I am FAIRLY positive that the non-GSR bars are 13mm.
I wouldn't use this bracket for an ITR bar for the simple fact that a 22mm bar puts a *LOT* more stress on the subframe than a 13/14mm bar.
Comptech has the best solution out there, by far.
Old May 25, 2003 | 09:26 PM
elwood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkyeC &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't use this bracket for an ITR bar for the simple fact that a 22mm bar puts a *LOT* more stress on the subframe than a 13/14mm bar.
Comptech has the best solution out there, by far.</TD></TR></TABLE>
I dont think that the beaks kit would be any better than the
honda bracket. I just dont like spending money when I dont
have to. Whats the comptech setup? Post a link or pic.
oldbeefcake
Jul 31, 2008 10:27 PM
allenp
14
Aug 3, 2006 01:46 PM
Lissav
Suspension & Brakes
Apr 9, 2006 06:52 PM
spock_rocker
May 23, 2004 06:43 AM
921.5CXEG
Jun 23, 2003 08:09 PM
