RC Injector Help....My OBD1 Clips Won't Work!!!
I finally got to install my RC injectors that I have had for about 9 months and finally put them in for the new turbo install. They went in fine and seem to fit OK with no leaks (Knock on Wood) but my OBD1 Clips won't fit on them. Did RC send me the wrong ones? How do I know what clips on these RC's? OH, these are custom 800cc Peak & Hold injectors.
Thanks in advance for any help.
I had to trim a piece of plastic out of my Clips. their wasn't a slot in the Injectors for it and it was not letting the clip go down on the injector. Take a look in the injector and the clip. You should be able to figure it out from there.
The RC peak and holds are like that....I had the exact same problem with my RC 550s....there was a little plastic line inside the injector side of the clip, but the honda clip does not have the slot for it to go into..... it was blocking it from connecting....i just cut it out with a razor.
Thanks guys. I did a little trimming and everything is all good. Thanks to Sonny for the help too.
vlc92189
21
Mar 6, 2009 12:06 PM
Panoply
Jul 18, 2005 09:36 AM
SlamMan
Jun 13, 2003 04:41 PM
