1st gen vtec sol. gasket???
on a 1st gen b16 what vtec sol. gasket do i use? i tried to use a us b16 del sol gasket ( its the same as 00-99 si) it did not work. the gasket are just a tiny bit different, but enough not to be interchangeable.
will the b17 vtec sol. gasket work? does anybody have the b17 vtec sol. gasket part number?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rathead »</TD></TR><TR><TD CLASS="quote">on a 1st gen b16 what vtec sol. gasket do i use? i tried to use a us b16 del sol gasket ( its the same as 00-99 si) it did not work. the gasket are just a tiny bit different, but enough not to be interchangeable.
its not different. are you trying to use a DOHC gasket on a SOHC?
There's no VTEC del Sol B17 - nor a B17 VTEC model variant (from the factory). All the head gaskets from the B16 del Sols will be the same. Try cross-referencing part numbers on http://www.autozone.com or something.
EDIT: I meant a B17 VTEC model.
Modified by clm at 10:34 PM 5/25/2003
Are you talking about the gasket on top or on the side (where ths solenoid meets the head)? I used a 99-00 Si side vtec solenoid gasket but couldn't quite figure out which gasket to use for the top portion of the vtec solenoid.
lilrexSI-r
Nov 30, 2004 04:16 PM
Francois
Jul 10, 2002 05:06 AM
