What radiator do you have,Why?
Old May 25, 2003 | 12:10 PM
jdmh22bubble's Avatar
Default What radiator do you have,Why?
I have an EG with an h22a and I have cooling problems,I have changed the radiator with a 2 core and new honda termastate,and fan presure swith.It still reads tem. dead on half way or above,do I need a better radiator,and if so what kind.HELP!
Old May 25, 2003 | 12:13 PM
Default Re: What radiator do you have,Why? (jdmh22bubble)
Also if you have any pics if h22 civics with aluminum radiators what fan do you use.
Old May 25, 2003 | 12:19 PM
yeaaaa its slow's Avatar
I have a stock radiator, because there is nothing wrong with it
Old May 25, 2003 | 01:12 PM
nsxmatt's Avatar
Default Re: What radiator do you have,Why? (Quick EX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quick EX &raquo;</TD></TR><TR><TD CLASS="quote">I have a stock radiator, because there is nothing wrong with it
Same here. Flushed the system, new water pump, thermostat, temp switch. Runs cool even in drive thru's
Old May 25, 2003 | 01:18 PM
hybrider's Avatar
Default Re: What radiator do you have,Why? (nsxmatt)
never had ONE problem with the stock civ radiator, runs great.
Old May 25, 2003 | 02:38 PM
flat-blk-HB's Avatar
Default Re: What radiator do you have,Why? (hybrider)
I too had cooling problems with my 92 civic with a D16Y8 with a HM turbo set-up and then I tried flushing the system, putting on a pusher fan(between the IC and radiator)....Still did not work so I got a Del SOl dual core and that has seemed to fix everything...............Have you tried running your fan constantly?
Old May 25, 2003 | 02:57 PM
B_CRUZ!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmh22bubble &raquo;</TD></TR><TR><TD CLASS="quote">Re: What radiator do you have,Why? </TD></TR></TABLE>
stock 5th gen CX.
... because I am too broke to buy a Integra or Dual core DOHC one.
Old May 25, 2003 | 03:03 PM
JV's Avatar
JV
Who?
Default Re: What radiator do you have,Why? (B.CRUZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B.CRUZ &raquo;</TD></TR><TR><TD CLASS="quote">
stock 5th gen EX .
... because I am too broke to buy a Integra or Dual core DOHC one. </TD></TR></TABLE>
Me too...
Old May 25, 2003 | 04:56 PM
Lord Helmet's Avatar
Default Re: What radiator do you have,Why? (JV)
I got a C&R radiator because my stock one finally went bad after 136K+ miles. it's kinda of a overkill since I could've gotten another stock one but I just wanted a better cooling efficiently.
Old May 25, 2003 | 05:04 PM
WOLFPACK's Avatar
Default Re: What radiator do you have,Why? (sleeperciv)
Old May 25, 2003 | 05:25 PM
I wanna be Steve!'s Avatar
Stock EG...works great...my ECT sensor went out so instead of replacing the sensor I just made a toggle switch for the fan. Wasn't coming on at all. Now that I can use it when the car gets hot(which is not often at all) all is good.
P.S. All was fine until sensor went out...good radiator/fan.
Old May 25, 2003 | 06:23 PM
Default Re: What radiator do you have,Why? (flat-blk-HB)
No i haven't tried running it constantly but i had my system flushed,and new presure swicth,termastate,and an aftermarket factory replacment 2 core radiator,and FAL thin fan and still the tem. gauge stays at 1/2 or alittle above and some times it goes 3/4 way up before the fan will kick on. Where do you guys temp gauges stay(1/2,or3/4) and with a C&R,or Fluyidyne does the temp. gauge still stay 1/2 or what.
Old May 25, 2003 | 07:01 PM
fOmaNPu's Avatar
I have some no name Bullet racing radiator. Car stays nice and cool.
I had no problems with my stock one, but when we did my swap we bumped the tranny on it and it cracked.... go with a Koyo w/ thin fan or a Fluidyne if you're looking for the best.
Old May 25, 2003 | 07:16 PM
Snoopy1's Avatar
Default Re: What radiator do you have,Why? (fOmaNPu)
Have you checked to make sure your temp. gauge works correctly? Maybe the needle is reading wrong.
Otherwise you shouldn't have a problem with the setup you have, so I don't know what else would cause it.
Old May 25, 2003 | 07:25 PM
blkgsr03's Avatar
i have a fluidyne radiator. no overheating prolems at all
Old May 25, 2003 | 07:26 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Stock has been working fine in my 92 Civic w/ B18C1.
If it ever dies I have had a dual core del Sol radiator sitting in my garage for over a year.
Old May 25, 2003 | 07:53 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: What radiator do you have,Why? (SkyeC)
stock cause it gets the job done...no need to upgrade when no change will occur
Old May 25, 2003 | 07:59 PM
elwood's Avatar
Default Re: What radiator do you have,Why? (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">stock cause it gets the job done...no need to upgrade when no change will occur</TD></TR></TABLE>
.....cough.....cheapass......cough......
Stock engine+stock radiator. I have a gsr radiator sitting in my basement.
Old May 25, 2003 | 08:08 PM
MPower332TI's Avatar
Default Re: What radiator do you have,Why? (d15dude)
I am using the same radiator as i was using when i had an H22 in my car. Its an auto EX dual core with a slim fan from Advanced auto parts. It never got hot at all and the fan worked great. Seems to me that your guage is off. Get an autometer water temp guage and see whats up
Old May 25, 2003 | 08:10 PM
redline201's Avatar
i went from my stock cx radiator to the del sol dual core radiator
never ran my b16a with out it so i have nothin to compare it to
but
it was cheap
so i upgraded
try importrads.com
i think mine is made by koyo
Default Re: What radiator do you have,Why? (Snoopy1)
now that you have said that i never noticed it untile i put my JDM SIR EG gauge cluster,maby it is alittle off.But i have new water pump and everything,with the setup i have i souldn't have any problem.And i don't want to get a fluyidyne and have to get another fan because of clearnce problems,I had to get the shortest clutch bleeder i could find when i put the thick dual core radiator in,if i get any thing thicker i will have to put the fan on the front side of the radiator,it's very close now.!
Old May 25, 2003 | 09:47 PM
milo's Avatar
i have this...dual core for delsol vtec... lower and upper rad hoses fit nicely
Old May 26, 2003 | 10:59 AM
anyone else,any more pics-sounds like everyone has almost the same setup. Any more ideas
Old May 26, 2003 | 11:49 AM
JKim0901's Avatar
I had a B18c5 in a EG and i always had bad luck with radiators also i just sacraficed the ac and put a integra radiator in it
The best picture i have
Old May 26, 2003 | 12:06 PM
boostedcivicsir's Avatar
Mr. Badwrench
fluidyne. with a FAL
reasons:
1 still have ac.
2 space. (turbo)
3 front mount.
4 had a little extra money.
5 built motor with solid deck sleeves now.
stuie08
Jan 22, 2008 01:10 PM
eightvalver
Sep 22, 2007 01:17 PM
Maxpower350
Jul 16, 2006 06:56 PM
4piston
Jan 27, 2005 07:11 PM
BoostedH23a1
May 7, 2003 11:19 AM
