this a ? for those turboed ludes (please dont lock)
Old May 25, 2003 | 12:09 PM
d98clturbo's Avatar
Default this a ? for those turboed ludes (please dont lock)
i am posting this here cuz it is more related to the preludes (h22)
please dont lock
i am currently running a t3/t04b turbo (too small for me)
this turbo actually feels like it falls flat on its face at about 6000rpm's...
so here is the thing i am looking to upgrade my turbo..Which turbo should i get?here are my choices:
T3/T04E 60 TRIM w/ .82 A/R TURBINE
COMPRESSOR SPECS:.60 A/R HOUSING, 60 TRIM WHEEL
TURBINE SPECS:.82 A/R HOUSING, STAGE 3 WHEEL
T3/T04E 60 TRIM w/ .63 A/R TURBINE
TURBINE SPECS:.63 A/R HOUSING, STAGE 3 WHEEL
T3/60-1 w/.63 A/R
what are you guys running and what do you suggest
Old May 25, 2003 | 02:20 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: this a ? for those turboed ludes (d98clturbo)
is you engine built??
Old May 25, 2003 | 03:27 PM
Ima2nr's Avatar
I have a turbonetics 60-1, T4 flange w/.58 A/R housing, 3" exhaust
engine is fully built--- it makes 448 whp on 93 octane gas daily driven
Old May 25, 2003 | 07:24 PM
d98clturbo's Avatar
i have wiseco 8.8:forged pistons on a 95 block (not sleeved) and shotpeened rods the head is stock ...i am running 15psi right now but like i said this turbo falls off at about 6000
Old May 25, 2003 | 08:59 PM
spoolinlude's Avatar
I live under a rock
Default Re: (d98clturbo)
wow........ guess that answers my questions about the weisco pistons abilities..... how long has this been running??....... got for the 60-1 n see how long they last!!! worth a shot
Old May 25, 2003 | 09:59 PM
munscher's Avatar
Default Re: this a ? for those turboed ludes (Ima2nr)
damn, i was in canton, ga yesterday.... wish i had stopped by to take a look!
Old May 25, 2003 | 10:25 PM
KTeller8's Avatar
Default Re: this a ? for those turboed ludes (munscher)
go with a Persicion Turbo
get a SC54 or 60
Old May 26, 2003 | 04:06 AM
symba's Avatar
I would take a look at the compressor maps for the t3/t4e 60 trim .63a/r turbine and the t3/60-1. Most likely, the t3/t4e will be more efficient but that depends on the boost pressure you want to run. I have the t3/t4e 60 trim .63a/r turbine.(not installed yet, just a really pretty paper weight right now)...
Old May 26, 2003 | 05:25 AM
d98clturbo's Avatar
Default Re: (spoolinlude)
i have had these pistons in my motor since august of last year over 12000miles now...
the thing is i dont want to buy a turbo that will do the samething this one is doing (run out of breath at 6000 rpms) i want a bigger turbo that will make power straight through the rpm range...
oh yea i also forgot to mension that i have the SDS engine management system and 550cc injectors...if that helps
Old May 26, 2003 | 05:26 AM
Boostless97Lude
Guest
Posts: n/a
i will soon be usine a Precision SC61 myslef
Old May 26, 2003 | 04:52 PM
LJR-LUDE01's Avatar
I would go for a t3/t60-1 after seen that you have no problems with your block not been sleeved.
Tchleung
Jul 23, 2004 12:49 PM
HYBRID_H@TCH
Aug 26, 2003 12:30 AM
d98clturbo
May 26, 2003 08:54 AM
95%
Apr 15, 2003 11:35 AM
specie
Jan 15, 2003 05:52 PM
