h22 with boost or h23 with boost
I am thinking about a motor swap but i am not sure on which would be better with boost. I have heard the h22 doesn't like boost, but it has more power to start with.
I have a 3g lude with 10lbs of boost, a water/air IC, a/f controler, 8.0 comp weisco pistons and stock rods. considering external wastegate and ignition to bump up to 15-20 lbs. But I wont be at the same hp's as a h series with the same boost levels.
