Spoon N1 fitment issues...
Old May 24, 2003 | 11:59 PM
skafia's Avatar
25 Year Member
Default Spoon N1 fitment issues...
It appears that there are fitment issues with different b-pipes + spoon N1 not just with my Apex N1 B pipe.
My b pipe has nothing to do with the angle of the exhaust because I took the axleback off of the apex b pipe and let it hang freely on the hangers and it is still way to the left.
It appears that the position of the left hanger is the culprit. The left hanger is wedge high because of that little metal bar that sits below it. Maybe I can hacksaw that sucker off?
I took the left hanger off of the exhaust and snapped some pictures, it sits perfect:
I ghetto-wedged a piece of cardboard in the left hanger's place until I can figure out what to do.
Here's a before picture with the hangers on the wrong spots:
Any suggestions or insights anyone?
Old May 25, 2003 | 12:32 AM
Saga's Avatar
Default Re: Spoon N1 fitment issues... (skafia)
I have a question, does the apexi n1 bpipe have a resonator in place? Do you happen to know the size of it?
Old May 25, 2003 | 01:20 AM
itr1244's Avatar
Default Re: Spoon N1 fitment issues... (Saga)
are you saying it's too short?
you can just go to muffler shop and extend the pipe .
it's probably because the difference length in the cat usdm cat VS jdm cat.
some b-pipes are made to fit jdm cat length some are made for usdm cat length.
good luck
or is it even for ITR's it could be one for the civics?
Old May 25, 2003 | 01:26 AM
skafia's Avatar
25 Year Member
Default Re: Spoon N1 fitment issues... (itr1244)
Yeah, doesn't seem like the hanger would reach...
Old May 25, 2003 | 05:25 AM
EKen9's Avatar
I have problems where the b-pipe meets the axleback. it is hitting up against something and is annoying as hell.
Old May 25, 2003 | 06:14 AM
Nate B's Avatar
Default Re: Spoon N1 fitment issues... (EKen9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKen9 &raquo;</TD></TR><TR><TD CLASS="quote">I have problems where the b-pipe meets the axleback. it is hitting up against something and is annoying as hell. </TD></TR></TABLE>Believe me you're not the only one, I bent the heatshield some more this morning and it seems to have gone away for the time being, but I'm sure the rattle will be back in no time.
Old May 25, 2003 | 06:41 AM
2lowintegra's Avatar
Default Re: Spoon N1 fitment issues... (Nate B)
bend the exhaust hangers..... when i first put on my n1, i experienced some rattle, but then my buddy, who is a mechanic at a muffler shop, bent the hangers a bit until the exhaust was perfectly centered and was not close to any heat shields... no rattle from then on
Old May 25, 2003 | 06:47 AM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: Spoon N1 fitment issues... (2lowintegra)
Mickey aka TypeRyo has just a small tad of rattle but its expected IMO. Bend the hangers, Take it to an exhaust shop and have them redo the hangers, or keep tryin to rig.
Good luck to you...it looks great though
Old May 25, 2003 | 11:11 AM
Ferrell's Avatar
Default Re: Spoon N1 fitment issues... (Stunna BEN)
That is exactly where my T1R rattles..... I Ghetto rigged a piece of rubber in there but it eventually fell out.
Old May 25, 2003 | 12:22 PM
SpoonSpecR's Avatar
I have this problem as well! What the hell is that? I have been under my car a hundred times and can't seem to come to any conclusions. We need to put our heads together here... Or hope someone smarter posts the answer
Has everyone had this with their stock ITR exhaust as well? Or just aftermarket b pipes and axle backs?
Old May 25, 2003 | 01:11 PM
N1-R's Avatar
New User
Default Re: Spoon N1 fitment issues... (SpoonSpecR)
are you sure the bushing will not reach the left-correct hanger? try it and snap some pics for us.
If that doesn't work, either ur car's left hanger is f8cked or your spoon's left hanger is f8cked.
and i'm thinking the N1 might be the problem.
Old May 25, 2003 | 01:37 PM
skafia's Avatar
25 Year Member
Default Re: Spoon N1 fitment issues... (N1-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N1-R &raquo;</TD></TR><TR><TD CLASS="quote">are you sure the bushing will not reach the left-correct hanger? try it and snap some pics for us.
The bushing reaches the left hanger, but it pulls the spoon n1 to the far left making it crooked.
UPDATE - I just fixed the problem. I went to Autozone and bought a cheap hanger and cut a 1/4 notch out of the side that hits the metal bar, installed it and BAM, perfect!
Old May 25, 2003 | 01:46 PM
skafia's Avatar
25 Year Member
Okay. I am NOW satisfied completely
Old May 25, 2003 | 01:58 PM
Mike M's Avatar
Founding Member
Well the problem is Not a problem with the exhaust.
The Problem is because you are using a B Pipe that the Axleback was not designed to fit to, But just happens to somewhat fit to. So in that case it becomes a Custom Job and you will end up having to play around with gaskets, hangers etc to get it to sit right.
The Spoon N1 AxleBack was designed to Bolt to an 1)OEM B Pipe, 2)Spoon B Pipe, 3)T1R B Pipe, 4)Vision B Pipe, 5)Any other B Pipe made to fit in the stock B Pipes place perfectly.
Old May 25, 2003 | 02:18 PM
skafia's Avatar
25 Year Member
Default Re: Spoon N1 fitment issues... (Mike M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike M &raquo;</TD></TR><TR><TD CLASS="quote">Well the problem is Not a problem with the exhaust.
Mike, as I stated above I removed the axleback from the APEX bpipe and still had the same fitment issues. I've also noticed that other members on this board who have the Spoon N1 and either the OEM B pipe or the T1R B pipe have the same problem.
We all know what the Spoon N1 fits onto. No need for the bold
Old May 25, 2003 | 02:30 PM
Mike M's Avatar
Founding Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skafia &raquo;</TD></TR><TR><TD CLASS="quote">
We all know what the Spoon N1 fits onto. No need for the bold </TD></TR></TABLE>
I know you know, but just in case others didn't (Since people ask me all the time)
I've never had a problem with the Spoon N1 Fitment with my OEM or T1R B Pipes
Old May 25, 2003 | 02:37 PM
skafia's Avatar
25 Year Member
Regardless, thanks again Mike. I really love the muffler!
Old May 25, 2003 | 03:01 PM
Mike M's Avatar
Founding Member
NP
BTW here are a few pics of mine on my car with T1R B Pipe.
Old May 25, 2003 | 04:37 PM
EKen9's Avatar
I do have a T1R b-pipe and I'm still having a problem of it vibrating against something
Old May 25, 2003 | 05:45 PM
Mikes01GSR's Avatar
I have been having the same noise it's a nasty metal on metal vibration noise that happens after the running the car hard then letting the rpms fall to somewhere around 3400 rpms. For the longest time I thought it was my cusco cf rear strut tower brace and figured out today it was my spoon n1. What's happening is the right hanger of the spoon n1 is coming in contact with the metal bar that is near the rubber hanger on the chassis. It been rubbing it so bad it took the paint of the metal piece on the chassis. I wedged something between the two now for a ghetto rig and have not yet heard the noise. Hope this helps.
Old May 25, 2003 | 06:26 PM
EKen9's Avatar
Default Re: Spoon N1 fitment issues... (Mikes01GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikes01GSR &raquo;</TD></TR><TR><TD CLASS="quote">I have been having the same noise it's a nasty metal on metal vibration noise that happens after the running the car hard then letting the rpms fall to somewhere around 3400 rpms. For the longest time I thought it was my cusco cf rear strut tower brace and figured out today it was my spoon n1. What's happening is the right hanger of the spoon n1 is coming in contact with the metal bar that is near the rubber hanger on the chassis. It been rubbing it so bad it took the paint of the metal piece on the chassis. I wedged something between the two now for a ghetto rig and have not yet heard the noise. Hope this helps. </TD></TR></TABLE>
yup that's exactly what I'm talking about
Old May 25, 2003 | 06:41 PM
Nate B's Avatar
I've located my rattle to be the resonator on the bpipe vibrating with the rear portion of the 2piece heatshield
Old May 26, 2003 | 01:48 AM
skafia's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Saga &raquo;</TD></TR><TR><TD CLASS="quote">
I have a question, does the apexi n1 bpipe have a resonator in place? Do you happen to know the size of it?</TD></TR></TABLE>
Yes. It has a resonator, but I don't know what size, I can take pictures and measure for you if you're really interested...
skafia's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike M &raquo;</TD></TR><TR><TD CLASS="quote">NP
Mike, you need to wash your car and take updated pictures
buffalos
Jun 17, 2013 09:51 PM
JCL
Jul 6, 2006 12:07 AM
JDM RHD eg6
May 9, 2005 07:32 PM
Skeletor
Jun 14, 2003 07:02 PM
