Hood pins on an EF..
Where do you guys mount the rods for your hood pins? I was trying to figure a spot along the piece that goes above your headlights, but the headlight is right underneath it.
Does anyone have any pics by chance?
Haha SiZ havent seen you on forever man here or SHO. Check out my site when you get a chance, http://www.garageTUNERS.com
Some of the ones ive seen people pull the headlight out, drill, put in the rod, then put the headlight back in. Atleast on EFs.
From: hittin corners so hard you can taste my rims..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 point 6 »</TD></TR><TR><TD CLASS="quote">some of the ones ive seen people pull the headlight out, drill, put in the rod, then put the headlight back in. Atleast on EFs.</TD></TR></TABLE>
the ED's and adjustable headlights have a backing plate of the headlights, if you go threw that, and the topside.. it will jack up your headlight alignment.. now the true EF's have 1 peice plastic headlights, and if you pulled them out, mounted your posts, and stuck them back in, it would be perfect.
just wondering if you really had a EF, or you just like the way it sounds?
I guess my car isn't a TRUE EF.. But this is the "EF Civic" forum, so I assumed most people would have a pretty good idea of what car we're talking about.
Thanks for the help some people.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A »</TD></TR><TR><TD CLASS="quote">
just wondering if you really had a EF, or you just like the way it sounds?</TD></TR></TABLE>
just wondering do you really have a EF8 and a real JDM EG or did you have a ED...do you have a real JDM EG or a EJ?
