99 gs-r and i'm having problems with my skunk2 intake manifold
Hi my name is Tom. I just bought the skunk2 intake manifold and i'm having a lot of trouble setting up the hoses the right way. These instructions are a little bit confusing when discussing the T-fitting, pcv valve, evap hose and purge controll soleniod valve. if someone can just tell me wat hose to hook up to wat i'd greatly appreciate it.
thank you.
thank you.
Have you tried searching the archives for your question? I'm sure there are tons of threads on the Skunk2 IM since many people on this site have it. As a rule of thumb - Its best to search first and if you're not satisfied with the result, then ask your question.
Welcome to HT.
Welcome to HT.
I searched the archives. a lot of people have trouble, but not the same problems as me apparantly. It says to use a t-fitting and attach the pcv valve to the evap. it could either be the evap purge controll soleniod or it could be the canister. also the purge controll soleniod has 2 openings there for hoses to attach. which one do i use? if anyone can tell me how to hook up the vaccuum lines i'd really really appreciate it. hopefully i can get this lil project done in under a week.
99gs-r
May 27, 2003 11:47 AM
