jdm integra type r octane
Old May 24, 2003 | 06:42 PM
$N@kE's Avatar
Default jdm integra type r octane
hey u guys. Im considering dropping in a jdm integra type R engine in my civic. Does anyone know what octane level it runs on? Ive heard it runs on 100, but can it run on anything lower than that without damaging the engine or lossing power?
Old May 24, 2003 | 06:44 PM
RTW DC2R's Avatar
Default Re: jdm integra type r octane ($N@kE)
if u dont run nitro then its not even worth buying the motor.
Old May 24, 2003 | 06:45 PM
$N@kE's Avatar
Default Re: jdm integra type r octane (RTW DC2)
what? nitro?
Old May 24, 2003 | 07:40 PM
RedR's Avatar
lol
Old May 24, 2003 | 07:47 PM
$N@kE's Avatar
Default Re: jdm integra type r octane (RedR)
instead of saying lol... can u plz tell me what it is? guessing that ur laughing @ me that u kno what it is right?
Old May 24, 2003 | 07:51 PM
ArmyGreenITR's Avatar
they can run 93,in japan they have 98 at the pumps so they run that but it will do fine on 93 in the usa.
Old May 24, 2003 | 08:13 PM
$N@kE's Avatar
Default Re: jdm integra type r octane (ArmyGreen EG)
uhh... highest ive seen @ the pumps in CA was 91....
r u absolutely sure u can use 91 on a jdm integra type r engine designed to use 100, and not lose any power? or well not alot?
Modified by $N@kE at 6:33 AM 5/25/2003
Old May 24, 2003 | 08:19 PM
oh well sucks for you cali guys we have 93 here in FL but 91 will also be fine
Old May 24, 2003 | 10:26 PM
JDMparts4u2
Guest
Posts: n/a
I had a 1998 Spec R JDM motor in my old Type R ran fine stock 91 hit 13.9 bone stock (well I had a clutch and flywheel) hahahah secret
you will be fine on 91 gas just run your stock brain and make sure you add CAS crank angle sensor
later
Old May 24, 2003 | 10:45 PM
CHRIS 1.8's Avatar
We have 100 octane at the pump at some gas stations.
Old May 24, 2003 | 10:46 PM
YelLowITR's Avatar
Default Re: jdm integra type r octane (CHRIS 1.8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHRIS 1.8 &raquo;</TD></TR><TR><TD CLASS="quote">We have 100 octane at the pump at some gas stations.</TD></TR></TABLE>
yeah, i have seem that at 76
Old May 24, 2003 | 11:07 PM
Spikey's Avatar
Default Re: jdm integra type r octane (YelLowITR)
Japan uses a different octane rating scale than the US.
Thus, Japanese 100 octane is not equivalent to US 100 octane, closer to 95/96 here.
JustLooking's Avatar
Hi,
You can run on pump gas up to 11.5cr as long as you don't advance your timing.
Old May 24, 2003 | 11:36 PM
Nameless RB26's Avatar
Default Re: jdm integra type r octane (JustLooking)
Of course 91-92 is ok. You don't need to bother with timing or whatever blah blah.
It's only 11:1 compression. The US S2000 is 11.5:1.
I've heard of people running over 12:1 on 92-93 octane.
Old May 25, 2003 | 02:09 AM
ballsoutracecar's Avatar
Default Re: jdm integra type r octane (zyg)
the AUSDM ITR has same compression as JDM and the manufacturer claims in car manual that anything lower than 95 will cause loss in performance. Luckily we get readily available 98 / 95 and our lowest unleaded is 91/92.
If your going JDM ITR, go for 95(really do try lookikng for 98 though)-98+. This is the fuel the Japs use, well try 100+ readily available from the pump over there, and thats why JDM are that little bit better, because they have an easy availability of high octanes fuels and they build their domestic cars with this in mind.
USDM run on, like you say 91, if your lucky 93ron which is why it isnt as powerful or come wiht extra goodies as the JDMB18C.
Can you imagine an engine built and designed to run ATLEAST 95ron but tuned to excell at 98-100+ and then it ends up in an environment where 93 is its only option. Not too shabby. Unless you bother looking for high octane service stations and use octane boosters, or get the USDMB18C-5. It will be better suited to the fuel.
Many may disagree, but octane is a big factor in engine performance. It doesnt create HP, but more allows the engine to run and be tuned to peak performance.
Old May 25, 2003 | 04:27 AM
MiraiZ's Avatar
Default Re: jdm integra type r octane (ballsoutracecar)
Its 96 Octane minimum (recommended) Japan sells 96-100 octane at the stands
Old May 25, 2003 | 04:58 AM
DutchITR1689's Avatar
pump octane (USA) = (RON + MON) / 2
RON = Research Octane number
MON = Motor Octane number
In Japan, Europe, Aus people are using RON. US pump Octane &lt; RON
http://www.btinternet.com/~mad....html
Old May 25, 2003 | 11:15 AM
civicdee's Avatar
They have 100 octane around here racing fuel like $5 a gallon or something. I will sell you a tanker full at 2-3x the price.
jk
Old May 25, 2003 | 12:20 PM
GokuSSJ4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zyg &raquo;</TD></TR><TR><TD CLASS="quote">Turn the timing back a bit and you should be fine.
Will probably lose some power over the JDM specs.</TD></TR></TABLE>
you shouldnt have any problems , i ran mine on 91 octane for 2years with no problems . but if you can put higher octane go for it .
theyre some gas stations that have them here but are rare .
Can some of you Cali(specially south cali ) peeps name some gas station that you are aware that sale higher octane then 91 at the pump.
Old May 25, 2003 | 04:00 PM
jansenrw's Avatar
ok my.02.. anyone read the toluene thread.. cant find it ATM... arr apparently toluene can solve your problems!!!
EgHatchy96
13
Sep 30, 2013 03:43 PM
PaJeeZy
Feb 20, 2009 02:35 PM
Civtegrar
May 4, 2005 11:09 PM
Solscud007
Dec 27, 2004 04:31 PM
fuzzypunks
Oct 8, 2003 03:44 AM
