Changing Drive Axles?
Old May 24, 2003 | 05:35 PM
EVIL_AWD's Avatar
Default Changing Drive Axles?
Do you have to drain the tranny fliud to change change out axles. I'm just wondering, consider a break an axle at the track and I need to replace it really fast, can I do it without draining the fluid? Thanks in advance.
Old May 24, 2003 | 05:47 PM
Jared's Avatar
Default Re: Changing Drive Axles? (ITR420)
Depends on how the car is angled, sometimes fluid will drain out when you pull the axle out, but if you jack it up high enough on the side you're changing you'll be ok.
Old May 24, 2003 | 06:04 PM
Foozball26's Avatar
Default Re: Changing Drive Axles? (Jared)
you can do it without draining if both sides are jacked up. Otherwise it will drain out of the input holes b/c of the sideways angle
kpop
19
Nov 30, 2023 08:42 PM
Vagitarian
17
Aug 3, 2012 08:45 AM
Layziebtnh055
Apr 27, 2004 11:27 PM
EVIL_AWD
May 24, 2003 06:28 PM
civcexcoupeblack
Sep 19, 2002 04:27 AM
