Need some B21A1 specs.
Old May 24, 2003 | 02:39 PM
ahnold's Avatar
Default Need some B21A1 specs.
Anyone know specs. for b21a1: deck height, rod length, piston compression height, piston dome volume, piston pin diamenter and length? Thanks for any help!
Old May 25, 2003 | 11:00 AM
boostedlude3g's Avatar
Default Re: Need some B21A1 specs. (ahnold)
yea try http://www.NTOPG.org
go to specs.
Old May 25, 2003 | 04:42 PM
ahnold's Avatar
Default Re: Need some B21A1 specs. (boostedlude3g)
Thanks for your help. I checked out ntopg. I found a b series engine info spreadsheet, but the info doesn't seem right. It states the deck hight of the b21 is 189.20mm, the rod is 141.7mm, and the stroke is 95mm. According to those specs, 1/2 of the stroke (47.5) + the rod length (141.7) = 189.2 (the deck height). This is impossible. This would put the end of the rod above the deck. What about the piston? This spreadsheet is consistantly wrong with all the other deck heights as well. Anyone know the real specs.?
mx125cc
Jan 23, 2015 03:24 PM
hondamark35
Jan 19, 2008 10:50 PM
Junior_r
May 23, 2004 09:33 AM
gulf imports
Jul 22, 2003 05:00 AM
