in middle of swap. help please
Old May 24, 2003 | 01:31 PM
turbo sol's Avatar
Default in middle of swap. help please
my z6 i am putting in doesnt have a spot to run the coolant line from the head to the throttle body, can i just plug the line at the head? or should i tee it in to anouther coolant line at the TB.
2. what do i do with the vacumm line coming out of the purge cut-off soleniod valve? one line is running to the charchol canister and the other used to go the the TB, but there isnt a spot for it now. do i tee that into a regular vacumm source.?
any help and esp. photos of the old map sensor area and throttle body coolant lines. would help.
Old May 25, 2003 | 05:41 AM
turbo sol's Avatar
Default Re: in middle of swap. help please (turbo sol)
well i t'd the purge cutt off into another vacumm source adn i think i am goign to cap the coolant line, if anyoen see's a problem with this let em know.
Mutiny1
Feb 20, 2010 07:28 AM
SlipGear
Jan 19, 2008 02:33 PM
igo4bmx
Apr 8, 2004 07:25 PM
t3to4e
Dec 24, 2003 10:56 AM
ARACER25
Oct 13, 2002 10:41 AM
