Need HELP on removal of moulding under window!
Old May 24, 2003 | 11:36 AM
Robo_Wop's Avatar
Default Need HELP on removal of moulding under window!
AHHH! the black moulding part underneath the window is all cracked on both of my doors...looks like complete asssssss...how do i remove it? i took out the door panel, and there seems to be clips holding the moulding and squeegee **** on it...how do i take it out?
Old May 24, 2003 | 12:17 PM
skribblah's Avatar
Old May 24, 2003 | 12:40 PM
Robo_Wop's Avatar
Default Re: Need HELP on removal of moulding under window! (Robo_Wop)
wicked thanks...
but umm...how do the clips come off?
Old May 24, 2003 | 12:59 PM
Slurp56's Avatar
I have yet to get one of those off without snapping all the clips. Not a biggie, the new pieces come with clips.
roll the window down and grab a hold of the moulding. Then slowly and gently kind of tip it from the inside of the car to the outside. It will flex and one at a time the clips will pop. Order the new piece first and just snap it on in the old ones place.
Old May 24, 2003 | 07:45 PM
Robo_Wop's Avatar
awsome thanks...worked great
Old Jul 27, 2006 | 02:10 PM
2000Accord5sp's Avatar
Sorry to bring an old thread back but I can't for the life of me find this part number on hondaautomotiveparts.com for my 93 eg.
Does anyone have a part number for both driver and passenger sides?
Old Jul 27, 2006 | 02:35 PM
b16ej1lsd's Avatar
1. remove door card.
2. put window all the way or or take it out
3. get a flashlight and look at the clips holding on the molding from the inside of the door.
4. use a pick or a small pry bar to pull back on the clips while someone else is gently pulling up on the molding. start at one end and work towards the other side.
this way you dont need to buy new clips
Old Jul 28, 2006 | 06:38 AM
So any idea what part #'s are needed to replace it once you get it off?
Old Jul 28, 2006 | 07:01 AM
tatmark1's Avatar
flat head screw driver from outside
slide screw driver under and push in clips. EASY
use your head so you dont scratch your paint
its # 25 in that parts diagram look the # up
edit: wow just relized old thead
B16Power
Apr 26, 2011 10:40 AM
welfarepc
16
May 13, 2009 10:55 PM
Turboredteg
May 12, 2007 07:01 AM
89hatcher
Mar 5, 2007 08:51 AM
BigChris
Sep 25, 2003 03:05 PM
