Lowest fuel pressure with large injectors??
Old May 24, 2003 | 10:23 AM
turbosi03's Avatar
Default Lowest fuel pressure with large injectors??
Does anyone know if there is a certain fuel pressure I should not adjust below with large injectors?
-I'm running 76.5lb (780cc I think) driven by Hondata S100 w/Boost base maps
-AEM fuel pressure reg.
-STR fuel rail
-Holly 255lph pump
Right now the fuel pressure is set to 40psi @ wot, and 32psi @ idle. It's still pretty rich so I want to make sure it would be safe to go down to 30psi @ wot if I had to, and the injectors will still run the same.
Thanks for any help!
Old May 27, 2003 | 06:09 PM
E Swift's Avatar
Default Re: Lowest fuel pressure with large injectors?? (turbosi03)
Mine runs around 34 at idle.
Old May 27, 2003 | 06:11 PM
PM-Performance's Avatar
Default Re: Lowest fuel pressure with large injectors?? (E Swift)
I think RC says not to run lower than 30psi
Old May 27, 2003 | 06:34 PM
ladysman's Avatar
Default Re: Lowest fuel pressure with large injectors?? (itr206)
I run 45 with my RC 800cc's.
Jan 31, 2010 02:46 PM
Djbower1
Dec 27, 2005 02:56 AM
aalb1
Nov 2, 2005 10:47 AM
niedejb
Mar 28, 2002 02:06 PM
