will 00 si brake pads fit on a 98 integra gs?
Old May 24, 2003 | 08:46 AM
_Shadow_'s Avatar
New User
Default will 00 si brake pads fit on a 98 integra gs?
anyone know if they will fit? TIA
Old May 24, 2003 | 10:41 AM
WiggiE's Avatar
New User
Default Re: will 00 si brake pads fit on a 98 integra gs? (_Shadow_)
I don't believe the fronts will work as they are listed as a different part number. The rears are the same though.
Old May 24, 2003 | 02:02 PM
_Shadow_'s Avatar
New User
Default Re: will 00 si brake pads fit on a 98 integra gs? (WiggiE)
OK thanks, I just looked at my pads and they are fine. I am hearing this noise coming from the rear like a squealing type sound. It sounds like worn out pads scraping but the pads look fine. Any ideas what it could be? Anything I should check?
Old May 24, 2003 | 02:08 PM
WiggiE's Avatar
New User
Did you check both the inboard and outboard pads? The inboard pad has a tendency, due to the single piston design, to wear faster.
Make sure you check both pads on both sides of the car.
cletus11
13
Sep 21, 2011 08:25 AM
theineffable
Honda Civic (2001 - 2005)
Sep 8, 2010 11:18 PM
laur
Sep 3, 2010 07:28 PM
PatrickGSR94
Suspension & Brakes
Jun 2, 2008 03:17 AM
GRM Scott
Sep 12, 2001 09:40 AM
