My car always CEL 17 VSS how do I fix it..?
Old May 24, 2003 | 08:42 AM
bossman032's Avatar
Default My car always CEL 17 VSS how do I fix it..?
my car always give Code: 17 VSS speed sensor.
I have a interga throttle cable maybe thats why or something..?
I reset my ecu it goes away for a while then it appears again.
I am using a si cluster on my STD car!!
Old May 24, 2003 | 09:37 AM
blackc's Avatar
Default Re: My car always CEL 17 VSS how do I fix it..? (bossman032)
Is youre speedo functional?
Old May 24, 2003 | 09:43 AM
RCautoworks's Avatar
Default Re: My car always CEL 17 VSS how do I fix it..? (dldom)
Is your vss hooked up ? Take it out of the trans and clean it up, make sure its in tight. If they don't work, make sure everything looks ok on the ecu side.
Modified by 90blackcrx at 5:19 PM 8/28/2003
Old May 24, 2003 | 09:48 AM
bossman032's Avatar
Default Re: My car always CEL 17 VSS how do I fix it..? (90blackcrx)
hey guys,
my speedo works but it tweaks when the car starts up it starts to move up and down slightly when the car is cold but when car ideal and warms up it stops to tweak.
yea its on tight with the pin on I will clean that baby up today and try it..
Maybe I need an interga speedo cable because I am right now using a STD hatchback cable!!
thanks for the replys guys
Old May 24, 2003 | 11:34 AM
turboZChatch's Avatar
1 make sure it is comletly pluggd in like everyone else said on the tranny and the gauge cluster
2 the cable could be messed upin some way if it dosn't work after y ou plug it in well make sure it is plugged in and deisconnect baterry cables rub together then start again just get a new cable
Old May 24, 2003 | 12:15 PM
bossman032's Avatar
Default Re: My car always CEL 17 VSS how do I fix it..? (turboZChatch)
Yea I just went ahead look at that **** I pulled out the cable inside that speedo cable and put it back hopefully it won't give the CEL anymore.
Will let you guys know when I take it for test drive.. its plugged in at the back of the Cluster pretty good it won't come out because the clip is on tight..
Thanks for the inputs guys!!!
Old May 24, 2003 | 06:09 PM
bossman032's Avatar
After I took out that ****, cleaned it plugged it in and after I drove for about 15-20 the Code 17 popped up again
What can be wrong..?
Old May 24, 2003 | 06:46 PM
bossman032's Avatar
Just took at the look at the wiring.
Going from b10 OBD1 to b16 on the OBD0.
What else can be wrong maybe the dam cable is fucked or cluster?
14
Aug 23, 2010 10:43 PM
aaronhume
Nov 21, 2006 12:00 PM
mzaner
12
Jul 29, 2006 09:18 AM
saikouEF8
Mar 28, 2006 09:42 AM
dirtracer
Feb 9, 2005 06:36 AM
