First year JDM HID front end can be used
What was the first year that the JDM HID front end can be used on a Teg. I saw somewhere a while back someone said the HID version couldn't be used in a certain year because the power steering pump got in the way or something like that. Any one have any more details. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicboy »</TD></TR><TR><TD CLASS="quote">What was the first year that the JDM HID front end can be used on a Teg. I saw somewhere a while back someone said the HID version couldn't be used in a certain year because the power steering pump got in the way or something like that. Any one have any more details. Thanks
Basically 94-97 integras (LS and up) have ABS pumps that are too big for the HID ballasts to fit. With an Integra 98+ you don't have to worry about it. But that doesn't mean that you couldn't detach the ballast and move it somewhere. It's extra work but HID's OWN.
</TD></TR></TABLE>Basically 94-97 integras (LS and up) have ABS pumps that are too big for the HID ballasts to fit. With an Integra 98+ you don't have to worry about it. But that doesn't mean that you couldn't detach the ballast and move it somewhere. It's extra work but HID's OWN.
it is definitely NOT worth it to buy the OEM HID. Just get the regular black housing headlights and buy some Phillips HID's.
-Andrew
-Andrew
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stealth 95 GS-R »</TD></TR><TR><TD CLASS="quote">it is definitely NOT worth it to buy the OEM HID. Just get the regular black housing headlights and buy some Phillips HID's.
-Andrew</TD></TR></TABLE>
boy I hope you're ready to get flamed
Some Philips HID kits sell for about $500 or so, give or take a hundred. Non-HID JDM front ends sell for about $1700 (a la passwordjdm). OEM HID JDM front ends sell for about $2300. Do the math, and it comes out to around $600 difference between OEM HID and non-HID kits. $2-300 difference max. Ask anybody on this board- most likely they'll tell you that the OEM HID beam pattern is much better than using an aftermarket kit in the non-HID projector. I've seen integobsession's lights in person... words can't explain it
there is always group buys going, you can get nice kits for $350-$375 shipped, you gotta know where to look.
I've seen HID's in stock Integra projectors, and it looks fine...
-Andrew
I've seen HID's in stock Integra projectors, and it looks fine...-Andrew
Thanks for the info guys
trying to decide if I want to keep my hatch and save up for my S2000 or sell my swap and my hatch and get a Teg(maybe a Type R) Thanks again for the info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stealth 95 GS-R »</TD></TR><TR><TD CLASS="quote">there is always group buys going, you can get nice kits for $350-$375 shipped, you gotta know where to look.
Have you seen OEM HID? If not, your opinion is not backed up by fact but rather than opinion.
Please do not mis-inform people about philip's hid is comparable to the OEM hid. The truth is, the OEM HID is better than an aftermarket kit in an oem non-hid projector housing.
I've seen HID's in stock Integra projectors, and it looks fine...-Andrew</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">
Please do not mis-inform people about philip's hid is comparable to the OEM hid. The truth is, the OEM HID is better than an aftermarket kit in an oem non-hid projector housing. </TD></TR></TABLE>
well said
I've seen both, I guess I prefer the way Phillips looks (I haven't seen any other aftermarket kits though). We both have our opinions.
-Andrew
-Andrew
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AcIntegGSR00 »</TD></TR><TR><TD CLASS="quote">i thought all of the third gen integ's had ABS</TD></TR></TABLE>
The 94-97 ABS unit is different from the 98-01. The 98-01 is smaller.
JDM front end people, how can you run jdm itr OEM HID headlights with the big ABS unit on 94-95 GSRs
chaudanova
Oct 26, 2005 12:13 AM
ATL-R
Jun 8, 2003 11:18 AM
