What's the scoop? (bogging, stalling)
Old May 23, 2003 | 07:49 PM
yorktonite's Avatar
Default What's the scoop? (bogging, stalling)
Alright, the last couple days I've been having a problem with my car. The car will start up fine and I will drive it and it will kind of bog/hesitate and sometimes it will stall after it has bogged/hesitated. Also the car will stall when stopped at a traffic light(sometimes). It doesn't happen at any certain rpm and it doesn't matter if the engine is cold or warm.
Usually it will start up right after it has stalled on me, the longest it took was about 5-10 seconds after it was stalled to start up again.
I've searched on this topic and it seems to be a few problems that other members have had so I went out today and bought a few things and replaced them.
Here they are:
-New cap & rotor
-New plugs & wires
-Replaced fuel filter
-Replaced PCV Valve
I reseted the ECU after and let it idle for about 10 minutes.
I'm still having the problem of the car stalling, any other ideas?
Old May 23, 2003 | 08:42 PM
WiggiE's Avatar
New User
Default Re: What's the scoop? (yorktonite)
Check your timing. Also may want to do a compression test.
Old May 23, 2003 | 09:01 PM
yorktonite's Avatar
Default Re: What's the scoop? (WiggiE)
I haven't got a chance yet to check either.
It might be fuel related. The car smells like gasoline after it has died.
Mad Third Gear Vtec
Mar 25, 2009 09:20 PM
emooheo
Aug 9, 2007 03:35 PM
prophetjinn
Apr 28, 2006 12:24 AM
myRice
Nov 20, 2005 11:45 AM
