Anyone Using Stock CR(B18c1) with Toda b's or Skunk2stg2/Jun3's?
I'm running jun 3's with stock compression. Its a major difference over stock, but I know I can do a lot better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Al Bundy »</TD></TR><TR><TD CLASS="quote">I'm running jun 3's with stock compression. Its a major difference over stock, but I know I can do a lot better.</TD></TR></TABLE>
And you have a GSR?
And you have a GSR?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WiggiE »</TD></TR><TR><TD CLASS="quote">
And you have a GSR?</TD></TR></TABLE>
Yes sir
Yes sir
the compression in the GSR is pretty low for an all motor build up should consider raising the compression to take full advantage of those cams......i got a ported and polish with skunk stage 2 cams.....waiting to be install......
its gonna suck i am gonna run stock bottom end i will lose hella compression due to the type r flow characteristc
any dynos?
any dynos?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kelvin96GSR »</TD></TR><TR><TD CLASS="quote">
any dynos?</TD></TR></TABLE>
AL, have you dynoed your car running Jun3s on your stock (10:1) CR?
i don't run toda b's or jun3's, but i do run itr cams with a mugen head gasket.
with my setup, it is hard to make power unless you increase the compression. it would be even harder with toda b's/jun3's.
hmm...maybe that was my buddies problem..
I dont know if he upped the CR...
he said he tried some Jun cams, and wasnt impressed
will stick with skunk or itr
