?? How do I remove the turn signal switch
Hey all, I have a bad turn signal switch on my 90 Si Hatchback that I need to take off, how do I go about doing that...
Thanks in advance !
Thanks in advance !
From: the asshole of america..., upstate new york, USA
i know the whole assembly with turn signal and wiper switch pulls straight off when you take the steering wheel off. as far as changing just the turn signal...? it must pull apart somehow.
Take off the H on the center of the wheel. Get a deep 19mm socket and extension and turn it until it comes off, then the wheel will pull off. Then you can loosen some screws and pull off the various handles. Other screws will release the handles from the main thing. I did it before, its not hard.
4thgenhatch is correct...use a 3/8 ratchet (dont worry ..the steering lock
should hold ) and off the nut will come..a philips screw driver is all you need
to remove a few screws and just unplug it...simple 15-20 min job actually.
way2much
Apr 19, 2005 12:44 PM
