Exhaust bypassing valve 50$
Old Jul 12, 2001 | 06:53 PM
Mighty Mouse's Avatar
New User
Default Exhaust bypassing valve 50$
This valve is hooked up to your exhaust system (pereferably before the cat) and is opened from the inside of car above 3k rpm. The exhaust will bypass your cat and exhaust and give you a full open exhaust giving you more hp. You must make sure that you open it above 3k rpm cause you do need some back pressure to create torque at the lowerer rpms!!!!! YOu can view it here. It fits 1.3/4 - 2.25" exhaust. For an NA you dont need it bigger than this.
http://www.thepartstrader.com/upload/ACF457B.jpg
this is a pic of it.
tek_civic
Aug 16, 2003 01:59 PM
dplatt
Mar 1, 2003 09:44 AM
slowone
Feb 22, 2003 01:01 PM
