wanna run an OBD1 motor in your 88-91 civic/crx?
Old May 23, 2003 | 08:41 AM
red civic standard's Avatar
Default wanna run an OBD1 motor in your 88-91 civic/crx?
your car must be a stock 88-91 mpfi car to use this harness (crx hf, si or civic si).
this is the engine wiring harness that is already converted to OBD1. The injector plugs and distributor plugs will fit right onto OBD1 components. You will also recieve the OBD0 to OBD1 conversion harness that must be plugged in at the ecu.
Looking to get 250 shipped.
PM me or email at wilcoxl@umich.edu
Old May 24, 2003 | 11:49 AM
KevronsEG's Avatar
Default Re: wanna run an OBD1 motor in your 88-91 civic/crx? (red civic standard)
Old May 24, 2003 | 12:29 PM
Si-Yaaa!'s Avatar
Default Re: wanna run an OBD1 motor in your 88-91 civic/crx? (CIV616)
Would you seperate the harnesses? I already got a obd0-obd1 coversion harness, but not a converted wiring harness. Let me know, and a price shipped to Ca 92673. Thanks!
hYbRid_Eg6
Jul 20, 2010 12:58 PM
93siturbo
Apr 10, 2009 06:22 PM
91hatch_on17's
Sep 2, 2003 08:27 PM
TurboSiCoupe
10
Feb 1, 2003 07:10 PM
