just put in zc and it wont start help
ok heres the situation zc is in the car connections are done and everything is in i plug in the pm6 ecu and try to start but the motor doesnt even turn (shouldnt it at least turn over if the starter works) but nothing and the ecu is giving me code 10 which is some kind of temp control thing but i dont think that would affect my starting what do u think it could be any suggestions or comments are greatly appreciated
Check all your connections to your starter. You should have your Positive battery cable connected to the starter along with 1 other plug. Also check and make sure all your ground wires are connected good. And make sure your battery is not dead.
checked what u said and its right oh except there is a little ground wire thats next to the big one that goes from the cam coverto the chasis where does this little one go to it doesnt reach to anything
On your starter, next to you 12V connection, is a small plug with a male end on it. Make sure this is connected to the female plug on your wire harness. This may be the wire you are talking about. It won't even crank with out this wire connected.
Ya wanna race
Feb 1, 2006 07:07 PM
BIG RICH
Jan 29, 2004 08:33 AM
