Suspension travel
Old May 23, 2003 | 08:06 AM
jaymar88's Avatar
Default Suspension travel
Its not really ITR specific, and I understand the majority of you here don't lower you car to extremes, but any additional suspension travel is a good thing right?
https://honda-tech.com/zerothread?id=513961
They also look pretty cool. lol
Old May 23, 2003 | 08:28 AM
.RJ's Avatar
.RJ
Default Re: Suspension travel (jaymar88)
I have a set of these, in front and rear. Work great, no bottoming issues. They're only $75/pair
Old May 23, 2003 | 08:32 AM
Dave-ROR's Avatar
Default Re: Suspension travel (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">I have a set of these, in front and rear. Work great, no bottoming issues. They're only $75/pair</TD></TR></TABLE>
If I still had my bilstein/GC setup I'd pimp those.
Old May 23, 2003 | 08:34 AM
tonyxcom's Avatar
Default Re: Suspension travel (dawhiteboy)
Does anyone know if there are fitment issues with Tein HA's?
I know they will slide on the shock shafts, the springs should be a pretty close fit..
but..
we know how tall the shafts protrude past the hat, and I wonder if the extra 1 1/2 inch is enough to put the adjusters into your hood.
jaymar88's Avatar
How did you like the bilsteins? I was looking to purchase a set should I ever change setups. how well did they dampen the gc's? I know they're "self adjusting" but how well does that really work.?TIA
Old May 23, 2003 | 08:35 AM
jaymar88's Avatar
As far as I could tell, I still had room to spare when it came to hood clearance.
Old May 23, 2003 | 08:37 AM
Dave-ROR's Avatar
I loved the bilsteins. I admit that I had them near the edge of their ability with 450/600 lb springs.. but even then it wasn't bad. If you have lower rate's they'll damper just fine, (They did with my old ~270lb springs all around very very smooth)
Old May 23, 2003 | 08:38 AM
tonyxcom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaymar88 &raquo;</TD></TR><TR><TD CLASS="quote">As far as I could tell, I still had room to spare when it came to hood clearance. </TD></TR></TABLE>
With Tein HA's?
Old May 23, 2003 | 08:57 AM
jaymar88's Avatar
Default Re: Suspension travel (tonyXcom)
I've seen the ha's worst case scenario, you have to dril two small holes in the skeleton.
Old May 23, 2003 | 08:58 AM
tonyxcom's Avatar
Ok. thanks for the info. These have been on my To Buy list since I first found out about them, just needed this last bit of info.
autoraceparts.com
Sep 10, 2011 04:28 PM
DB_2o3
Suspension & Brakes
Sep 23, 2008 09:42 AM
K20Alex
11
Aug 22, 2007 11:01 AM
i-VTEC_do_you
Aug 28, 2006 09:41 AM
Halo
Honda Fit
15
Mar 8, 2006 11:23 AM
