FS: '88 CRX -maybe
Old May 23, 2003 | 03:00 AM
DSF's Avatar
DSF
Default FS: '88 CRX -maybe
SOLD
...I'm pretty sure
I’m testing the waters to see if anyone would be interested in purchasing my POS CRX. Option 1 is to sell it as is if the price is reasonable. Option 2 is to take off some of the parts that I want and donate the car to take it as a tax write off. I’ve included a list of everything I can think that is good and bad with the car. I snapped a few pics, but is was overcast. I can get more on request if there is a demand. I’ll either need to find the title (easier said than done) or go to the MVA to get a duplicate (likely outcome). FYI I’m in Baltimore MD. Make an offer, so I can see if it’s worth my while.
169+k miles
JHMED8459JS018015
· 1988 CRX DX was: 1.5L DPFI auto now: 1610cc MPFI VTEC 5spd.
· engine (@7000 miles on rebuild)
o (10.8-11.0:1CR)
o A6 block (bored and honed)/crank (micro polished)
o Y8 head ported intake ports/3 angle valve job
o Y8 intake manifold/TB
o ZC exhaust manifold
o NEW .5 OS OEM pistons
o NEW OS OEM rings
o NEW OEM wrist pins
o NEW ARP rod bolts
o NEW ACL bearings
o NEW gaskets/seals/belts
o NEW ZEX valvesprings
o regrind JG VT35 cam
o Skunk2 camgear
o 93 octane needed
· transmission
o ZC transmission
o Centerforce DF clutch
o equal length axles
· fuel/ignition
o PR4 ecu w/4 EEPROMs
o VAFC
o GS-R fuel pump
· suspension/brakes
o Matrix coilovers
o SI wheels painted flat black (2 curbed)
o 195/50-15 Kumho 712s
o Russel front stainless brake lines
o Tokico rear struts
o KYB front struts
· silicone filled engine/transmission mounts
· NEW radiator
· Matrix Cold Air Intake
· OBX Stainless Steel 2 ¼” Exhaust with tip cut (Stock cat)
· Wings West RS body kit
· VDO tach
· VDO oil pressure
· VDO EGT
· air-fuel/injector pulse meter
· rear loop from Autopower cage (saved from my old car)
· Boston Acoustics 6.5” door speakers/crossovers (saved from my old car)
· Panasonic tweeters (came with car)
· body and paint by (drum roll) Earl Schieb
o The paint on the drivers door/rocker is is peeling/bubbling.
o The paint on the passenger door is marred.
o The driver’s side rocker needs reinstalling.
o General dents, nicks, and whatever.
· Extra parts I could include if desired
o almost all a/c parts
o horns (high and low tone)
o 14b
o T25/downpipe/adapter plate (needs tapping)/HF manifold
o extra seat (dirty from sitting on back porch)
o rear wing (low OEM JDM SI style painted a Mazda Miata blue mica)
· Parts/services known to be needed
o brake master cylinder (brakes work, but are mushy)
o alignment (4 wheel)
o windshield (cracked from side to side)
o rack end bushing
o a/c compressor
o reinstall fuel pump (only pulls to ½ tank due to my ignorance)
o wire up reverse lights (pull wires from tranny reverse switch to reverse wires near shifter)
o install horns (have horns)
o degree cam (to correct cam/ignition timing)
o install PCV catch can (currently rigged)
Modified by DSF at 10:09 PM 6/25/2003
Old May 25, 2003 | 12:05 AM
The One Upper's Avatar
You Have PM
Old May 25, 2003 | 02:31 AM
91hatchcivic's Avatar
where did u get the paint job and how much was it? looks awsome, i wanna get mine done, and pm send btw.
Old May 25, 2003 | 10:51 AM
Turbo Powa's Avatar
Default Re: (91hatchcivic)
how much are you looking to get? PM ME!! I'm interested!!
Old May 25, 2003 | 10:55 AM
the paint is soo sexy! where did u get it done and how much was it?
Old May 25, 2003 | 11:54 PM
djay86's Avatar
hey man, how much for the wheels if you're interested in parting them out. I'm in MD.
Old May 26, 2003 | 09:26 AM
Default Re: (djay86)
damn man where are you?!? answer some questions
Old May 26, 2003 | 10:59 AM
DSF's Avatar
DSF
Default Re: FS: '88 CRX -maybe (DSF)
I think I replied to everyone (via PM).
Old May 26, 2003 | 02:04 PM
kshymkiw83's Avatar
price?
Old May 26, 2003 | 04:46 PM
DSF's Avatar
DSF
Default Re: FS: '88 CRX -maybe (kshymkiw83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kshymkiw83 &raquo;</TD></TR><TR><TD CLASS="quote">price?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSF &raquo;</TD></TR><TR><TD CLASS="quote">Make an offer, so I can see if it’s worth my while.</TD></TR></TABLE>
Old Jun 9, 2003 | 03:12 AM
DSF's Avatar
DSF
Ok, first and second buyers fell through. Unfortunately, I lost everyones PMs. So if your interested, PM or email me.
Thanks.
Old Jun 19, 2003 | 03:31 AM
DSF's Avatar
DSF
Last bump before I donate it.
Old Jun 20, 2003 | 02:48 PM
jester's Avatar
b4 u donate it I want some parts off it !
Old Jun 20, 2003 | 02:52 PM
Default Re: FS: '88 CRX -maybe (jester)
donate it? what do u mean ur giving the car away? i want it !
Old Jun 20, 2003 | 04:14 PM
hybridzOr's Avatar
Default Re: FS: '88 CRX -maybe (91hatchcivic)
I like what you used for your tach, Free bump for a sexy paint job
Old Jun 20, 2003 | 04:42 PM
Kg cm2's Avatar
Default Re: FS: '88 CRX -maybe (HybridRacer)
I PMed you. I'm in MD.
Old Jun 21, 2003 | 09:44 AM
durrett syndrome's Avatar
Default Re: FS: '88 CRX -maybe (Kg cm2)
whats that in the cluster?
Old Jun 21, 2003 | 08:06 PM
DSF's Avatar
DSF
Default Re: FS: '88 CRX -maybe (durrett syndrome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by durrett syndrome &raquo;</TD></TR><TR><TD CLASS="quote">whats that in the cluster?</TD></TR></TABLE>
It's a combination air/fuel meter and injector pulse monitor. I think it's from EFI Systems.
Old Jun 21, 2003 | 08:43 PM
integra-modder's Avatar
let me know what you are asking for this thing....
Danthemagicbum
Jun 29, 2011 06:48 PM
typac69
Apr 27, 2009 04:13 PM
Cory man
Jun 7, 2003 01:25 PM
