washer, extended bolt trick for rear camber on civics/integra
Old May 23, 2003 | 12:02 AM
HKSone's Avatar
Default washer, extended bolt trick for rear camber on civics/integra
anyone have the part #s for the washers and the extended bolts from home depot i have a 92 civic hatch..thanks
Old May 23, 2003 | 03:45 AM
J2turbo21's Avatar
Default Re: washer, extended bolt trick for rear camber on civics/integra (HKSone)
I dont think you need a part number for some washers.You should be able to tell just buy looking at them.
Old May 23, 2003 | 05:15 AM
dfoxengr's Avatar
Default Re: washer, extended bolt trick for rear camber on civics/integra (J2turbo21)
just get one that fits around the bolt and add/remove them to get the right size
Old May 23, 2003 | 10:42 AM
mike1114's Avatar
Default Re: washer, extended bolt trick for rear camber on civics/integra (hybridvteceg)
my bro has been looking for ever to find the right bolts, if you figure it out, let me know, I tried all parts stores, even Ace, they had some metric bolts but the ones that were closest didn't fit.
Old May 25, 2003 | 07:00 PM
ek_will's Avatar
Default Re: washer, extended bolt trick for rear camber on civics/integra (mike1114)
got the perfect size for mine from pepboys try them forgot actual specs tho
Old May 25, 2003 | 07:12 PM
.RJ's Avatar
.RJ
Default Re: washer, extended bolt trick for rear camber on civics/integra (dash0n)
be careful what bolts you use, i wouldnt trust cheap-o bolts from pep boys/lowes.
Try to find a stock bolt thats longer and buy it new.
Old May 25, 2003 | 07:29 PM
poison's Avatar
Default Re: washer, extended bolt trick for rear camber on civics/integra (.RJ)
Use the stock bolts. If you have more than 3° camber in the rear then there is some issues.
Make sure they are stainless steel bolts and match the metric thread pattern.
gsrious
Suspension & Brakes
12
Oct 31, 2005 11:35 AM
Slammed Ek9
10
Aug 8, 2005 10:15 AM
BigZ88
Oct 6, 2003 11:43 AM
Fuster_Cluck
17
May 17, 2002 10:43 AM
Fuster_Cluck
Apr 14, 2002 11:37 AM
